yagoolar's tube amp projects - Page 9 - diyAudio
Old 20th January 2013, 08:26 PM   #81
kevinkr's Avatar
Maybe we should call this the yellow light district...
Not sure if all of the bias leds for the 2A3 are red or yellow. There are incidentally jumbo red leds with vf of 1.9V with what I understand is typically slightly lower dynamic resistance than is the case with yellow leds, based on your results I would guess the yellow should be fine imo..
Glad to hear it is working well...
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 20th January 2013, 08:40 PM   #82
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
One yellow for Tesla E180F, 126 red ones - for one 6C4C. There was something wrong with CMPSA92 transistors, so replaced the with BF241.
Old 2nd February 2013, 09:43 AM   #83
yagoolar's Avatar
Default Output @ 100Hz, 1 kHz, 10 kHz
Here are voltage traces of the output loaded with 8.2 ohm resistor
Upper traces are input 1V/div
Lower traces are output 5V/div
100Hz .........................1 kHz.............................10 kHz
Old 2nd February 2013, 07:56 PM   #84
yagoolar's Avatar
Default Same condition except output xfrmrs are replaced
I used vintage push-pull output transformers in SE configuration as there is no DC current flowing through primary winding
Old 8th February 2013, 05:17 PM   #85
yagoolar's Avatar
Default New transfomer arrived
New output transformer arrived - tested it @10kHz. Results below. Sounds great.
Old 10th February 2013, 07:42 PM   #86
yagoolar's Avatar
Smile Almost finished - top plate to be made
Playing the amp for couple of days now. Some metal works need(top plate, cans for chokes and caps) to be done and is finished.
Old 8th November 2013, 05:28 PM   #87
yagoolar's Avatar
Artosalo and RajkoM made me come back to this project and do some tweaky-tweaky.
I am going to optimise driver stage operation point either
1. using BJT CCS, changing resistor values which set Ia current and adding heatsink to BF421 (TO-92)
2. use DN2540 cascode CCS if (1) will not work well.
You may find the discussion in here E180F V EF184
Thanks RajkoM and Artosalo
PS. This exercise will help me design GM70 parafeed driver, I hope.
Tube Amp Projects lpd Swap Meet 2 1st August 2012 11:05 PM
(new internal photo added)AcF's new tube amp projects Maniac Acoustic Fun 2 17th January 2011 10:39 PM
For sale - several audiophile DHT tube amp/preamp projects (UK) andyjevans Swap Meet 9 16th December 2009 03:49 PM
Hi guys, What tube amp projects are there for around $100 or less? NathanP Tubes / Valves 4 21st May 2002 05:53 PM
Thinking of building my first tube amp. Suitable projects? Erik Johansson Tubes / Valves 55 8th April 2002 11:28 PM
Copyright 1999-2017 diyAudio
