#71 |
You have PM
#72 |
#73 |
In case you're interested, I just finished an amp using a C3o (6.3V version of C3m) running resistor loaded as a pentode, cap-coupled to 300B.
#74 |
#75 |
I miss something and sorry for not reinventing the wheel - I used EF861 instead of C3g. Specs read Ug1=+9V, while there are schematics of preamps with this tube as an voltage amp + driver biased with cathode resistor. And Ug1 is set to -2.5V In respect to cathode. Is the latter correct?
#76 |
Question answered, after I had taken curves.
#77 |
I cut open aluminium cover of C3gs - both glass bulbs were broken.
![]() Fortunately new E180F has come this evening
#78 |
Where am I going wrong?
The trace comes from E180F anode, 10V/div. Input signal 0,7V RMS. |
#79 |
I used yellow LEDs for cathode bias. Vg1 measures 1.9V both tubes. Anode DC voltage is 145V and 147V. If I read the trace properly, tubes goes into cut off. Right?
#80 |
Still things to be corrected, yet fine results right from the start.
There is no resistor in the cathode - I used yellow LED which gives 1.9V, so needed additional voltage drop due to lack of proper model. MPSA92 is replaced with F241. Last edited by yagoolar; 20th January 2013 at 08:21 PM. |
| Tube Amp Projects | lpd | Swap Meet | 2 | 1st August 2012 11:05 PM |
| (new internal photo added)AcF's new tube amp projects | Maniac | Acoustic Fun | 2 | 17th January 2011 10:39 PM |
| For sale - several audiophile DHT tube amp/preamp projects (UK) | andyjevans | Swap Meet | 9 | 16th December 2009 03:49 PM |
| Hi guys, What tube amp projects are there for around $100 or less? | NathanP | Tubes / Valves | 4 | 21st May 2002 05:53 PM |
| Thinking of building my first tube amp. Suitable projects? | Erik Johansson | Tubes / Valves | 55 | 8th April 2002 11:28 PM |
