#51 |
#52 |
Was planning to write "correct" or "better"
#53 |
#54 |
#55 |
They are between g1 and a. But there is the question of how each of them interacts with electron flow while differently biased. I don't know. Staying with "classical" i.e. g3-k, g2-a.
After some power test I may be tempted to change. Last edited by yagoolar; 12th October 2012 at 07:48 PM. Reason: Second thought |
#56 |
thought you had it triode coupled ?
but I seen the size/value of resistor to anode debated a lot |
#57 |
Triode-connected. Yes. Resistor between anode and grid stops RFI
#58 |
btw, DHT Rob have a schematic with C3g-50 amp on his site
seems he connects g2 and g3 together, and then to anode with 100R is it different because of the IT |
#59 | |
IMHO, IT use does not imply connection presented in DHT Rob's schematic. |
#60 |
Datasheet reads U3=0V i.e. connected to cathode.
http://www.4tubes.com/DATASHEETS/SCA...-C/C3g-TFK.pdf |
| Tube Amp Projects | lpd | Swap Meet | 2 | 1st August 2012 11:05 PM |
| (new internal photo added)AcF's new tube amp projects | Maniac | Acoustic Fun | 2 | 17th January 2011 10:39 PM |
| For sale - several audiophile DHT tube amp/preamp projects (UK) | andyjevans | Swap Meet | 9 | 16th December 2009 03:49 PM |
| Hi guys, What tube amp projects are there for around $100 or less? | NathanP | Tubes / Valves | 4 | 21st May 2002 05:53 PM |
| Thinking of building my first tube amp. Suitable projects? | Erik Johansson | Tubes / Valves | 55 | 8th April 2002 11:28 PM |
