Old 6th October 2012, 10:29 AM   #41
disco is offline disco  Netherlands
disco's Avatar
Low, compared to .... a 270 ohm resistor?
jaap
Old 6th October 2012, 11:03 AM   #42
SY's Avatar
A single series string of 105 series LEDs gave a noise of about 2uV over 22Hz-22kHz (ref Valve Amplifiers, 4th ed). Not sure how many this amp used, but let's say 10. So that would correspond to roughly 0.6uV before paralleling. The noise of the paralleled strings would reduce as the square root of the number of parallel strings, so you could drop that by a factor of 2 or 3. So the noise is comparable to an ideal (zero excess noise) 270R at room temperature (which a cathode resistor is unlikely to be).
All moot, of course: the tube is far noisier.
If there's a sucker born every minute, where do the rest of them come from?
Old 6th October 2012, 11:28 AM   #43
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
It is actually 4 paralleled series strings of 26 LEDs per tube.
Old 6th October 2012, 11:37 AM   #44
SY's Avatar
OK, so about 0.5uV Possibly a bit less because Morgan had a dodgy solder joint which contributed to his noise measurement. Eother way, errrr, lost in the noise.
Thanks for the clarification.
Old 6th October 2012, 01:08 PM   #45
disco's Avatar
Looking at the Johnson noise from a 270 ohm resistor at room temperature: Vnoise(rms) = root(4kTRB)
k= boltzmanns' constant
T= abs temperature (293 degr Kelvin)
R= resistance
B= bandwith
4kT= 1.62 x 10~-24, times 270 ohms, times 21,980 Hz= 9.6 X 10~-18
Vnoise = 3.1 x 10~-9 = 0,003 microvolt/Hz~-1/2
That would be less than the LEDs. Is this white noise on the cathode complete harmless or can it lead to 'listening fatigue'? I have no clue how to implement these figures but some preferred the simple cathode resistor for prolonged listening while others preferred the immediate gain in weight on the bassnotes and stronger attack (not faster) with LEDs. Perhaps it's a case tot case study, how it mixes in with other shortcomings of our audio creations
jaap
Old 6th October 2012, 03:03 PM   #46
yagoolar's Avatar
R= resistance
B= bandwith
I am talking about substituting RC with LEDs.
The best way would be to compare apples with apples, i.e. measure the noise from R or RC in the similar conditions compared to LED tests.
As to calculations you should take 820 ohm resistor @ say 320 K. This will roughly give 0,02 uV/Hz. Is this difference significant to hearing? I don't know. I am a cello player with some orchestral experience, so I always try to compare real sound to what is reproduced. I perceive LED bias (vs. RC) more real.
Old 7th October 2012, 06:39 PM   #47
yagoolar's Avatar
CCS's for C3g plate mounted.Click the image to open in full size.
Old 8th October 2012, 10:13 PM   #48
yagoolar's Avatar
After having read a post on connecting g3 of C3g (to either cathode or anode/plate) while g2 connected via resistor, say, 220 ohm to plate, I am in doubt. Which one is ...
Source: http://audioroundtable.com/GroupBuild/messages/1999.html
Old 8th October 2012, 10:58 PM   #49
yagoolar's Avatar
Originally Posted by tcqanh View Post
why don't you use fixed bias for power stage ? it is simple and easy to adjust the operation point.
many people here gave up the LED bias....
I started thinking if there was a relation between DC across coupling cap and transferring signal via such polarized cap. DC voltages in fixed and cathode biases across a coupling cap may be significantly different.What is an impact on sound?
Started a thread in PARTS.
Old 9th October 2012, 08:15 AM   #50
euro21 is offline euro21  Hungary
Is this the correct phrase? There's no accounting for taste. :-)
Tube Amp Projects lpd Swap Meet 2 1st August 2012 11:05 PM
(new internal photo added)AcF's new tube amp projects Maniac Acoustic Fun 2 17th January 2011 10:39 PM
For sale - several audiophile DHT tube amp/preamp projects (UK) andyjevans Swap Meet 9 16th December 2009 03:49 PM
Hi guys, What tube amp projects are there for around $100 or less? NathanP Tubes / Valves 4 21st May 2002 05:53 PM
Thinking of building my first tube amp. Suitable projects? Erik Johansson Tubes / Valves 55 8th April 2002 11:28 PM
Page generated in 0.09034 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
