yagoolar's tube amp projects - Page 4 - diyAudio
Old 1st October 2012, 07:59 PM   #31
disco is offline disco  Netherlands
disco's Avatar
Is that high value for R3 necessary? Did the C3G suffer from oscillation?
Is there no noise issue on the 6C4C cathode with all those LEDs?
jaap
Old 1st October 2012, 09:19 PM   #32
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
Soldering is ahead of me. That is also my first experience with C3g - so your question is to be answered.
As for LED - I replaced RC cathode bias with LEDs and there was a huge improvement. I did not measure noise though.
Old 4th October 2012, 11:51 AM   #33
yagoolar's Avatar
Link to build thread of filament regulator for 6C4C
LM317 tracking pre-regulator and current regulator
Old 4th October 2012, 01:13 PM   #34
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
you could light up a house with all those leds
Old 4th October 2012, 02:00 PM   #35
yagoolar's Avatar
I will attach a pic when I fire them.Only 112 per channel See attached pic from other thread.
Old 4th October 2012, 02:03 PM   #36
just one tad bigger pictures, please
much too small to see anything
hey, btw, thanks to you(partly) I just now realized why voltage drop over the plate resistor should be calculated and added to supply voltage nice to know
Old 4th October 2012, 02:21 PM   #37
yagoolar's Avatar
Original post with bigger pictures.
12W Push pull w/6C4C
Glad I could help
Old 6th October 2012, 03:06 AM   #38
Originally Posted by yagoolar View Post
Recent schematic of the amp. Now assembly.
why don't you use fixed bias for power stage ? it is simple and easy to adjust the operation point.
many people here gave up the LED bias....
Old 6th October 2012, 07:26 AM   #39
yagoolar's Avatar
I am rebuilding the existing amp with LED bias, yet improving / experimenting with some elements i.e. filament power supply and driver stage. I decided to leave output stage bias as is. If I went to fixed bias I would have to change at least mains transformer, add another regulator. And then I would end up with another enclosure, and that would be new amp. I have 2 more projects on the table: SET w/300b and PP w/6C4C. So perhaps then.
Old 6th October 2012, 10:17 AM   #40
SY's Avatar
It's very low. Figure roughly 0.6-0.7nV/rt Hz per LED and the series string adds as power (not voltage).
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Tube Amp Projects lpd Swap Meet 2 1st August 2012 11:05 PM
(new internal photo added)AcF's new tube amp projects Maniac Acoustic Fun 2 17th January 2011 10:39 PM
For sale - several audiophile DHT tube amp/preamp projects (UK) andyjevans Swap Meet 9 16th December 2009 03:49 PM
Hi guys, What tube amp projects are there for around $100 or less? NathanP Tubes / Valves 4 21st May 2002 05:53 PM
Thinking of building my first tube amp. Suitable projects? Erik Johansson Tubes / Valves 55 8th April 2002 11:28 PM
Copyright 1999-2017 diyAudio
