yagoolar's tube amp projects - Page 2 - diyAudio
Old 26th October 2010, 12:06 AM   #11
kevinkr's Avatar
Originally Posted by yagoolar View Post
How can I tell they are "series 3"?
I no longer remember the specifics unfortunately - you'll need to Google for additional information - probably specific date code range. I gave up on them 10yrs ago and haven't looked back.
Consider them as fodder for experimentation and if they are better than that consider yourself fortunate..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 26th October 2010, 09:36 AM   #12
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
The tubes have the new logo: latin letter "S" not cyrillic "C".
BTW.
Your remark made me reconsider NOS 6C4C as an output triode.
Old 26th October 2010, 04:37 PM   #13
kevinkr's Avatar
BTW.
They might be late enough not to have the issue.. Mine were either winged "C" or Svetlana branded.
I think the 6C4C might be a safer choice, it's basically equivalent to the 6B4G, note the maximum plate voltage is only ~250V (fixed bias -45V) for these types and you'll get maybe 3W out in A1.
Old 26th October 2010, 06:43 PM   #14
45 is offline 45  Italy
45's Avatar
Kevin the 6C4C can take up to 360V anode voltage and as far as I have seen (directly) up to 16-17W without any problem. It's an improved copy of the RCA design, IMHO. The higher plate dissipation actually stands also for NOS 2A3's and good quality chinese production (like Golden Dragon and Billington Gold which I think come from the same factory...). You can get easily 4W and up to 6W (in class A2 using a simple source follower).
Actually there are some old American amps which used the 2A3's at 22W plate dissipation! I cannot remember the name now...they were from DIYers
45
Old 12th November 2010, 05:17 PM   #15
yagoolar's Avatar
Question C3g + 6C4C parafeed with mains xformer as OPT - sim
Kids are at their garndmother, there was a national holiday in Poland and at last I had time to proceed with the work with an amp. The result is the below shown schematic.
On one Polish forum I found interesting discussion on using mains transformers as OPT. www.trioda.com • Zobacz w?tek - trafo sieciowe jako g?o?nikowe. I measured inductances of primary and secondary windings of one toroid mains transoformer (50VA / 230V / 9V). The values are shown on the schematic.
On the next picture frequency response is shown, as simulated in LT Spice IV.
I also simulated the circuit with LED biased 6C4C (4 x 26 LEDs), yet the outcome is not satisfactory. Still some analysis to be done.
Comments are welcome.
Old 12th November 2010, 07:02 PM   #16
yagoolar's Avatar
The frequency response attached in the previous post seems unreal. What is worse, I cannot replicate the result.
Old 12th November 2010, 08:43 PM   #17
yagoolar's Avatar
I am a bit confused: why those two circuits make such a difference? Only a cap position changed.
Oh, and the OPT is not mains / power xformer. It is custom SE OPT: two primaries + two secondaries. In the schematics pris and secs are connected in parallel respectively.
Old 12th November 2010, 09:32 PM   #18
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
well, I was about to say that the ones I have seen had the cap connected to ground
and shouldnt the cap be bigger ?
what does two secondaries mean ?
sometimes we know very little, and sometimes we know too much
Old 13th November 2010, 02:16 PM   #19
yagoolar's Avatar
Find attached a circuit with C2 in range of 1uF to 100uF. Dark green line on the left refers to 100uF; more to the right - C2 goes down to 1uF
File Type: png 20101112 C3g 6C4C noled PF cap ano-trafo 1u-100u.png (68.3 KB, 579 views)
Old 13th November 2010, 02:26 PM   #20
yagoolar's Avatar
Here you have the simulation with the other variant. Strange - the response does NOT depend on the C2 value. My guess is it is not real.
File Type: png 20101112 C3g 6C4C noled PF cap cath-trafo 1u-100u.png (61.0 KB, 562 views)
Tube Amp Projects lpd Swap Meet 2 1st August 2012 11:05 PM
(new internal photo added)AcF's new tube amp projects Maniac Acoustic Fun 2 17th January 2011 10:39 PM
For sale - several audiophile DHT tube amp/preamp projects (UK) andyjevans Swap Meet 9 16th December 2009 03:49 PM
Hi guys, What tube amp projects are there for around $100 or less? NathanP Tubes / Valves 4 21st May 2002 05:53 PM
Thinking of building my first tube amp. Suitable projects? Erik Johansson Tubes / Valves 55 8th April 2002 11:28 PM
Copyright 1999-2017 diyAudio
