| diyAudio Sponsor | ||
Trying hard to come back to tube amps after some busy time since my last build (RDL by SY). I had collected a lot of tubes and decided to build something easy, small. Must be SE, parafeed and with Po not more than 10W. I have Svetlana 300B, 6C4C, C3g, 6H9C, 6C4Pi, 6C45Pi among others (GM70 as well, but still too little place to build such monster and too scared).
Ok, I am designing C3g+300B SE Parafeed with LEDs in cathodes. I would like to read your opinions on the posts while making progress. TIA |
#2 |
Schematic - first approach
I think of replacing R3 with CCS in the future. Last edited by yagoolar; 15th October 2010 at 09:08 PM. |
#3 |
wouldnt it be more like 5-6watt with parafeed 300B ?
#4 |
Something around 5,7 W w/C3g. Yes
#5 |
Found a reply on another forum regarding C3g and 300B from Thorsten Loesch: Tube DIY Asylum - Re: C3g as driver for 300b
I initially wanted to go 390V/60mA/-61,5V - and there is 430V/80mA/-77V in the post. The only 300B I have are 2 matched (?) SV300B from Svetlana Electron Devices Inc. (Made in Russia) dated Dec 2001. The parameters shown: Ia = 57|58 mA and S = 4,7|5,0 respectively. I wonder what was Ua... |
#6 |
#7 |
Started some output stage simulation with LT Spice. It seems that OP xformer params are critical to bandwitdh. And there goes the question: a transformer is represented by a couple of parameters, one of them is K coefficient - what is a good method to measure one in practice? My transformers were wound a few years ago and there is no chance I can find specs.
#8 |
A critical factor in a parafeed stage is the type of core you have in the OPT. The best type is the amrphous core because it doesn't store energy at low frequency. Never forget that decoupling cap + primary inductance = resonant circuit! The type of core is just critical as the cap.
45 |
#9 | |
How about fixed bias? Allows for very easy and rather revealing tuning of the operating point. It also eliminates some parts in the signal path at the expense of some additional (limited) supply complexity. And the Ia listed in the matching data are relevant to the matching only, and with good ones you can run them at any current that stays below 90% of the rated dissipation, and I have found generally the hotter you run them the better they sound. (and the more power you get at a given thd %) If you want a quiet amplifier heat the 300B with DC, and check out CCS based heating. Rod Coleman here has an excellent design just for this purpose.
www.kta-hifi.net |
#10 |
| c3g connections | garbage | Tubes / Valves | 8 | 16th October 2010 08:51 AM |
| to parafeed or not to parafeed that is the question | nhuwar | Tubes / Valves | 63 | 28th February 2007 12:29 PM |
| C3g | stecairoli | Tubes / Valves | 2 | 17th September 2006 07:02 PM |
| SET w/ 300B Ultrapath + Parafeed Typologies | eeyore | Tubes / Valves | 1 | 17th August 2005 12:40 AM |
| drd c3g/300b - help needed | garbage | Tubes / Valves | 15 | 1st February 2005 11:33 AM |
| Page generated in 0.11639 seconds (81.78% PHP - 18.22% MySQL) with 11 queries |
