EL34B 6N9P 5Z3P amplifier kit - any thoughts on schematic?
Old 13th October 2010, 02:03 PM   #1
sharpi31 is offline sharpi31  United Kingdom
Default EL34B 6N9P 5Z3P amplifier kit - any thoughts on schematic?
I bought a cheap amplifier kit from Hong Kong and have been sent the schematic in advance of the hardware.
I'd be very grateful if the more knowledgable inmates could offer any feedback on the design or possible improvements that could be made.
I plan on upgrading the coupling caps (larger teflon or PIO) and possibly changing to LED cathode bias (this worked a treat in my Hawthorne Spud).
Old 13th October 2010, 02:15 PM   #2
mashaffer is offline mashaffer  United States
Not sure I understand their approach. Fancy VAS/driver stage feeding a pentode mode EL34 with no feedback?
Generic Signature
Old 13th October 2010, 02:50 PM   #3
DF96 is online now DF96  England
The SRPP first stage is probably just a fashion statement. The pentode EL34 output will make it sound like a rather loud but well-mannered 1950's wireless set. Perhaps they originally intended to run it in triode mode, but then found it had too little output?
Sorry, but you did ask for our opinion!
Old 13th October 2010, 03:50 PM   #4
That's very helpful - please criticise all you like!
I'm keen to rejig the circuit as required to give best sound quality with these tubes and transformers. Power output is not important (I already have a 2-3W spud amp, and high efficiency speakers to match).
Any advice would be much appreciated :-)
Old 13th October 2010, 05:49 PM   #5
Eli Duttman is offline Eli Duttman  United States
As the other posters have indicated, it's a POS.
The easiest way to make something out of that dog pile is to disconnect the EL34 screen grids from B+ and tie them, via 100 Ω resistors, to their respective anodes. The result is triode mode, which will have tolerable (hopefully acceptable) characteristics in the distortion and damping factor departments. Power O/P will be 4 or so WPC.
Eli D.
Old 13th October 2010, 06:20 PM   #6
chrisb is offline chrisb
Reasonably well executed, a 4 watt triode connected EL34 P/P is not to be sniffed at, but as originally configured this "kit" might well be considered as organ donor for a complete redesign.
Eli - would a CCS loaded version of the 12AT7 LTP driver stage from your and Jim's El Cheapo design drive a pair of EL34? What I know for sure (courtesy of Eddie Vaughn) works "well enough" is a WE417 / Raytheon 5842
kinda burnt out - taking a break
Old 13th October 2010, 06:54 PM   #7
What about pseudo-UL? Put two resistors across the OPT primary, with their junction taken to g2. Could this match the existing transformer better than full triode mode?
Old 13th October 2010, 07:46 PM   #8
There's enough gain to drive no NFB triode wired EL34s. For an EL34 circuit with NFB, gain is insufficient.
That requires a buffering voltage follower of some kind. You be sure that the Chinese guano is on a PCB and not P2P wired.
Eli D.
Old 13th October 2010, 08:42 PM   #9
Thanks guys. The 'amp kit' is basically a set of tubes, drilled chassis and transformers with schematic and token cheap components. As it's point to point, I'm completely happy to go with a completely different scheme (whatever is recommended by you chaps).
Looks like it might be quite easy to build a version of the SRPP Eli & Ezequiel recommend in this thread: EL34 SE amp schematic
What would I need to do to accomodate the 6N9P/6SL7 instead of the 12AU7?
Here are some photos of the kit:
Old 14th October 2010, 12:21 AM   #10
rmyauck is offline rmyauck  Canada
I was looking for that one as I had printed it out! You may have to stick with 9 pin 6FQ7 or Octal 6SN7 as recommended if you don't want to change a lot.
EL34B 6N9P 5Z3P amplifier kit - any thoughts on schematic?Hide this!Advertise here!
Mengyue el34b schematic needed me32dc Tubes / Valves 2 9th March 2010 08:02 PM
6N9P data sheet vitalstates Tubes / Valves 4 8th December 2009 07:48 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 03:51 PM
MENG Series "EL34B" Integrated Amplifier stevenscoffee Tubes / Valves 2 8th July 2008 08:10 AM
Integrated Kit Thoughts? CptTripps Tubes / Valves 6 13th August 2003 06:25 PM
