| diyAudio Sponsor | ||
I got bored today and tried to come up with a 6B4G PPP amp. This is really rough so take it easy on a design newbie. The phase splitter is an input transformer, the main gain stage is 2 pentodes (6SJ7 or EF86, because thats what I have), the drivers could be any number of things 6SN7s or these 1626s I got. I'm mainly unsure about the negative supply for the drivers and the output tubes. I was hoping to run them both off of one supply and have some balance adjustment for the output tubes. So here it is, it will at least give you an idea of what I'm thinking of, even if its rubbish.
Athos |
#2 |
Or maybe something along the e-linear lines? I added another pot to the bias scheme. Thanks!
#3 |
Ok Last one, warmer colder?
#4 |
Even though 'm not getting any traction on this thread, I'll post what I fiddled with today. I lifted the frontend from the new Millett amp, and gave the CFs CCSs so that, "I think," I can keep the whole thing balanced. Rubbish?
Athos PS, I think I could run the CF's CCSs off on the negative supply I use for the Bias and the input. Last edited by athos56; 11th October 2010 at 05:58 AM. |
#5 |
Move the coupling caps from between two drivers to between the second and the output tube. You will need a negative supply. This will be the way to let the amp work in A2 where grid current is drawn.
Also I wouldnīt go for 6SJ7 or other low Gm tubes. Instead a good triode with mu 40-60 and no GFB. Maybe a triode-strapped 6SJ7 will do, but I havenīt got a clue.
Brgds Lars |
#6 |
Thanks for the look, the last effort I posted has some of those changes. I will look at changing the input, I'm not set on the pentodes, I just have a load of them I got for cheap
Athos |
#7 |
The actual desagn should be DPPP - Double Paralleled Push-Pull
![]() 6B4G has two paralleled triodes per se More paralleled triodes - less focus in detail |
#8 |
In your "Last one" you need to bias your CF's not to gnd but like you did in your previous schem.
Or you follow Revintages advice and move the caps. Then you need to use fixed bias for your CF's. /Olof
I'm not allowed to do magic, union rules... |
#9 |
Ok the caps are between the CF and the output tubes, and the driver's CCSs share the negative supply. I think that a single -50 to -60 negative supply can be used for the input, drivers and the output tube bias. Thanks for the input!
Athos Last edited by athos56; 11th October 2010 at 03:57 PM. |
#10 | |
"Move the coupling caps to between two drivers from between the second and the output tube"
Brgds Lars |
| Please help analyse 807 PPP | cjcc67 | Tubes / Valves | 38 | 2nd November 2009 08:04 AM |
| 6AS7 ppp | whitelabrat | Tubes / Valves | 12 | 15th May 2008 11:33 AM |
| The 6b4g | alexmoose | Tubes / Valves | 4 | 1st October 2006 10:02 PM |
| PP to PPP | amirmk | Tubes / Valves | 7 | 10th August 2005 05:26 PM |
| PPP transistor ? | Colt45 | Solid State | 5 | 3rd September 2002 10:38 PM |
| Page generated in 0.13643 seconds (58.48% PHP - 41.52% MySQL) with 11 queries |
