| diyAudio Sponsor | ||
Here's another past amp of mine. Right now it resides on the bench with only the 5Y3 in, and with three wires sticking out - for powering breadboarded circuits. Good for about 400V at maybe 50mA load. Anywho, schematic:
![]() Photo: ![]() - Real nice at night, you can almost read by it! Those heaters get *very* hot. The plates do too, I didn't realize it at the time but I was running way over limits, 300 vs. 120V max. screen for one , and two, 15W dissipation where 10's the limit. No redplate though, at least on reasonably matched tubes.Bottom: ![]() And yes that PS filter cap is octal! ![]() Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#2 |
IIRC, 6W6 is very high current low voltage. Should make a heck of a racket with 150V-200V and a very low impedance transformer, like 1K.
I've sometimes wondered if it was really a triple-size 6V6. > Those heaters get *very* hot. Cathode optimized for much higher current than this amp needs. With 300+V available and the usual 5K to 10K transformer, 6V6 should do very nicely and at a LOT less heater power. If you are very brave, you could wire 6W6 as Triode and get fantastic damping at 300V 10K load. At least until your screen grids got tired of the abuse and shorted the whole thing out. Are you saying 6V6 sounds better (in this design) than 6W6? I've wondered about using 6W6 in a low-Z amplifier but never saw one used as hi-fi audio. Shouldn't be bad, but hard to guess how "good" from the specs. |
#3 |
Yea, this amp was at the time when I put two and two together and - it works? fine for me...
![]() It would make a kick-*** amp if I put a 0C3 on the screens and had a lower-Z OPT. The OPT that's in there came from a PP 6V6 PA amp which claimed 25W output.. at 400V supply class A! Can you say red-plate... Tim
#4 |
Since you're using a cathodyne, I would just direct couple the front end while you're in there. I agree with the 0C3 change as well.
Joel |
| Archives of the Old Bass List | PB2 | Everything Else | 3 | 2nd June 2009 12:43 AM |
| linn lp12 archives | wrinaldi | Analogue Source | 0 | 27th April 2007 04:49 PM |
| PEARL audio archives | planet10 | Tubes / Valves | 4 | 22nd August 2002 05:52 PM |
| Polk DIY power port archives... | drakonis | Multi-Way | 3 | 28th March 2001 03:12 AM |
| Page generated in 3.53681 seconds (2.21% PHP - 97.79% MySQL) with 10 queries |
