Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
#11 |
Thank you, I can work with that. The B+ from the power tranny I have may be a bit on the high side, I think I can get it down to a reasonable value. Will start construction this week. And no problem trying lower G2 voltages too...
#12 |
Actually I have a question about audio transformer. Digging in a carton box I've found an all black transformer, I believe it was manufactured by Philips between 1959 and 1966. The secondary, depending on straps, is good for 14 or 7 ohm speakers. The code number is PK 51099.
Anybody can tell me about its specifications and if it is worth to use it for a PP amp of EL34 ? |
#13 | |
45, can you answer this question please? When a loadline passes way below the knee of the 0V grid curve, like in the loadline I posted, and the tube grid1 is driven to 0V, what actually happens to the tube or amp in this situation? I know its a bad idea, but I don't understand what happens, does it just square wave the output of the tube? 300b-luc, you can measure the primary impedance of your transformer, this will let you know what tubes it would be suitable for. There are a few threads around that describe how to do this. If you can't find one, let us know. |
#14 |
Ian444, even if I measure the primary impedence, due to my poor instrumentation I cannot get enough information to decide that the transformer is worth to be used for a PP amp. I hoped that someone had the Philips data sheet.
#15 | |
#16 |
Metalsculptor, thanks very much for the info. I have found very little info on PP loadlines regarding how hard you can go before something blows up, I guess *average* power dissipation is taken for granted by those who know the subject well. Now I understand...
I have begun drilling the top plate, work is in progress... Edit: 300b-luc, put 10 or 20V AC into the primary and measure the V AC at the secondary with no load. From that the primary impedance can be easily calculated. All you need is an AC supply and a multimeter. Last edited by Ian444; 12th October 2010 at 08:52 AM. |
Thread | Thread Starter | Forum | Replies | Last Post |
Output transformer for PP EL34 source | pof@ | Tubes / Valves | 7 | 22nd May 2010 09:09 AM |
EL34 PP motorboating questions | zigzagflux | Tubes / Valves | 5 | 14th September 2009 11:27 AM |
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? | ray_moth | Tubes / Valves | 4 | 23rd February 2007 12:22 PM |
EL34-PP building questions | tiagor | Tubes / Valves | 10 | 14th January 2004 10:35 AM |
New To Site? | Need Help? |
