Separate PSU to Amp connection
Old 7th October 2010, 11:37 AM   #11
Mosquito is online now Mosquito  Argentina
Mosquito's Avatar
Originally Posted by Hi-Q View Post
I guess the Health and Safety boys of today would not like it even though the Octal plug was used for many such applications in the past.
II'm a seasoned one, no Facebook no Tweet, and neither pets or kids around here..
"It is less serious than if worst"
Old 7th October 2010, 11:56 AM   #12
DF96 is offline DF96  England
250V ac means a peak of 350V, so not far short of your 500V. I would certainly be happy to use them at 400V. At 500V I guess you would just have to be careful, keep them dry etc. Above 500V you might need something with wider spacing.
Old 7th October 2010, 11:58 AM   #13
Doz is offline Doz  United Kingdom
Doz's Avatar
I don't think it's the pin to pin spacing that's the issue , with KV of breakdown listed in the spec. I suspect it's pin to finger spacing ! They aren't recessed very far.
Old 7th October 2010, 11:59 AM   #14
Hi_Q is offline Hi_Q  England
Hi_Q's Avatar
Yep, I was going to suggest Bulgin but I was not too sure on their availability at J's location. Just wondering if the contact rating can be pushed by not using contacts either side of the B+ one? They probably quote a lower figure based on creep-age between adjacent contacts under various levels of humidy etc. Some of their connector range do however go up to 2.5kV.
Old 7th October 2010, 12:03 PM   #15
Mosquito's Avatar
Thanks Doz and Hi-Q. I like the recessed male chassis socket and the female plug on the cable side. And the cable shield continuity detection is a clever idea too..
My B+ will be well under 500VDC so..
Separate PSU to Amp connectionHide this!Advertise here!
psu connection bigpanda Parts 3 11th May 2008 02:17 PM
Separate PSU grounding decky Power Supplies 1 20th March 2008 08:40 PM
LM3875 kit grounding, optimal grounding for separate amps and psu? findog Chip Amps 9 16th May 2005 09:27 PM
Separate PSU for analog stage of CDP (Elso pls take a look) static Digital Source 10 6th December 2003 02:21 AM
Separate Pre-amp or Inbuild debipilu Solid State 3 4th January 2003 08:13 AM
