diyAudio Sponsor
Old 5th October 2010, 08:08 PM   #1
Default 2C52 datasheet
Hello,
Does anyone has a complete datasheet of the 2C52 tube ?
I searched but found nothing, just an incomplete Raytheon document.
Thank you
Old 5th October 2010, 10:15 PM   #2
jlsem is offline jlsem  United States
jlsem's Avatar
I believe it is a 12.6V only version of the 12AX7.
John
Old 12th October 2010, 09:55 PM   #3
ke4mcl is offline ke4mcl  United States
Default 2c52
i have one in front of me and its no 12ax7. its an octal, very similar in appearance to a round plate 12SL7. i have over 8k tubes and the two i recently got are the first i have seen. i too am searching for data on it.
certified packrat
Old 13th October 2010, 12:31 AM   #4
tubelab.com's Avatar
I had over 100,000 tubes at one time. Most were military surplus. I have never seen a 2C52, but I do have several "specials" that fit the description.
Google found this:
Base Octal (Int.Octal, IO) K8A, USA 1935
Filament Vf 12.6 Volts / If: 0.3 Ampere / -: Indirect /
Description High-mu double triode. Mu 100. Designed for aircraft servo-amplifiers.
GE, Raytheon and Sylvania among known manufacturers.
Tube prices 0 Tube prices (visible for members only)
Literature Essential Characteristics, GE 1973
- - Manufacturers Literature
Tube Lore, Sibley, USA 1996
Google also found several 2C52's for sale.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 13th October 2010, 12:41 AM   #5
Tom Bavis's Avatar
Tube Lore says base is 8BD (same as 6SL7). Close to a 12SL7.
Old 13th October 2010, 10:41 AM   #6
Thanks for the inputs, yes 2C52 is 8BD, same pinout as 6SL7/ECC35, 12SL7, etc. mu=90
It will be used in a diy project with two tubes connected in SRPP so if someone knows what is the filament-cathode limit..
Maybe 90V like a 12SL7
Old 19th January 2011, 06:53 PM   #7
Specs similar to 12AX7, but in octal package as has been noted. I have a bunch of these, may try them in place of 12AX7s in a couple preamp projects. The links below show slightly different specs - some are the same.
http://tdsl.duncanamps.com/pdf/vm345.pdf (shows same as 12AX7, mu = 100)
http://www.wps.com/archives/tube-dat...-56-40M/12.JPG (shows mu = 90)
Anyone have curves for a 2C52? bst Tubes / Valves 1 22nd January 2010 10:08 PM
Datasheet shon35us Chip Amps 3 9th March 2009 03:10 PM
Looking for datasheet satelitis Tubes / Valves 3 9th December 2005 08:20 PM
Datasheet help Stocker Parts 0 10th March 2004 01:36 PM
Datasheet Piersma Digital Source 3 29th January 2003 07:49 PM
Page generated in 0.09756 seconds (71.93% PHP - 28.07% MySQL) with 11 queries
