diyAudio Sponsor
Old 2nd October 2010, 06:12 PM   #1
Default 2300 ohm vs 5000 ohm output trans question
Hi all,
WHats your take on using a 5000 ohm output transformer for quad kt88's?
I have a few amps now, and I think they use 2300 ohm output transformers.
Am I facing a power cut ( half the power than a lower rated trans) or I am getting an opportunity to use more output tubes (if I can use 4 on a 2300 does than mean I can use 8 on a 5000 ohm one)
I'm looking at using 120 watt power trans with 160 watt output trans using at least a quad of kt-88's (unless 5000 ohm trans are a 6l6/5881 item, then I can use those as well).
I'm thinking of a mono block architecture with individual power trans per channel.
thanks your your opinions and comments.
Old 2nd October 2010, 06:49 PM   #2
Hi Speakerfritz,
By using a 5000k output transformer you will have a power cut.
You will have about 30 watts/8ohm with quad kt88's in triode with the 2300 ohm output transformer.
With the 5k transformer you will end up with 13,8 watts/8ohm; output resistance (damping factor) and distortion will be lower though.
Pieter
Old 2nd October 2010, 07:11 PM   #3
Peter
Very good, thanks.
Old 2nd October 2010, 07:18 PM   #4
Arnulf is offline Arnulf  Europe
Exactly the opposite of that, if you double the number of tubes that are connected in parallel, you can halve the load impedance so if 2.3K was OK for 4 tubes, 1.15K would be OK for 8 to get identical operation for each individual tube.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 2nd October 2010, 10:17 PM   #5
tinitus is offline tinitus  Europe
and connecting 6ohm speaker to 16ohm output ?
Altec 806A 16 ohm to trade for 806 8A (8 ohm) diaphragms nelsondog Swap Meet 0 7th April 2010 12:32 AM
PHL Bass Midrange 8 ohm vs 16 ohm - same SPL: Why ? tiefbassuebertr Multi-Way 6 28th March 2010 06:14 PM
4-ohm Speakers on 6-ohm Amp? (newbie question) diesel_88 Multi-Way 23 25th October 2007 08:54 AM
How to connect 62 ohm headphone to 8 ohm output Sunsun22 Headphone Systems 15 16th June 2007 01:29 PM
What's the closest I can get to a 4 ohm load using 3 single coil, 6 ohm drivers? The Paulinator Multi-Way 9 11th May 2004 07:04 PM
Page generated in 0.09378 seconds (66.59% PHP - 33.41% MySQL) with 10 queries
