Has anyone used this regulator?
Old 2nd October 2010, 05:40 PM   #1
M Gregg is offline M Gregg  England
Default Has anyone used this regulator?
Has anyone used this regulator? I am refering to the HT side!
I am thinking of using a LM317T device in place of the LM317K because of low current requirements!
Does anyone see any problems with this?
Thank's for any input!
M. Gregg
Old 2nd October 2010, 05:57 PM   #2
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Hi, it probably will work but it is playing with fire. The dangerous moment is when switching it on. Because of the quite large cap at the output it could be that the voltage over the 317 exceeds the max. values by a large margin. Maybe TL783 is a better choice.
I remember Elektor using a 400 V max. rated reg but unfortunately I don't remember the typenumber. That one was also a 3 pin reg.
I found a few regs using parts that are rated for such high voltages.
http://www.linearaudio.nl/t-reg-2.htm
It's only audio. Member of the non modular PCB design committee
Old 2nd October 2010, 06:20 PM   #3
I will have a look thank's for your interest
Old 2nd October 2010, 06:27 PM   #4
Just for info I am restricted to a board size of 8cm x 5cm.
So you can see why I want to use a 3 pin reg.
M. Gregg
Old 2nd October 2010, 07:39 PM   #5
Lingwendil is offline Lingwendil  United States
Lingwendil's Avatar
Do a search for Linear brief 47, by Michael Maida. Very easy circuit to build and can easily be built with your size requirements. Very similar to the circuit you posted, just less complicated and more stable. You could also use the regulator from Sy's Red Light District amplifier.
Old 2nd October 2010, 07:45 PM   #6
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Better the Mosfet Maida, and a try with IRF820 may prove better in the highs.
Old 2nd October 2010, 07:53 PM   #7
Thank's everyone I will research all information.
Old 2nd October 2010, 08:03 PM   #8
Will the Maida circuit drop 400V to 250V?
Thought you might know the most you can drop across it?
Old 2nd October 2010, 08:45 PM   #9
O.K.
Thank's everyone I will try the Mosfet Maida. I will let you know how it goes!
M. Gregg
Old 2nd October 2010, 10:35 PM   #10
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
If you design it correctly and you provide an adequate heatsink.
I wouldn't try to drop any more power than you can safely dissipate with your heatsink or drop more voltage than your pass transistor can handle without breaking down. Other than that, you can dissipate 10000V if you can find adequate parts.
Has anyone used this regulator?Hide this!Advertise here!
Zener regulator with "integrated" pre-regulator 00940 Power Supplies 17 22nd July 2008 05:11 PM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
Regulator knuckles_mctug Digital Source 2 25th September 2007 03:14 PM
What is the best Regulator ? diy_everest Digital Source 27 16th July 2007 06:29 PM
Regulator argonrepublic Parts 29 21st January 2006 04:42 PM
Copyright ©1999-2017 diyAudio
