Would someone explain this amp to me please?
Old 2nd October 2010, 05:05 AM   #1
tom1356 is offline tom1356  United States
Default Would someone explain this amp to me please?
I'm not sure what's going on with this amp.
It uses two 12AU7's, two 1614's, and two 5R4GY's.
One Amperite 6n045 relay.
The iron is a UTC LS-10X input , a Peerless R-800-A Power, Peerless S-265-Q output, and Peerless C-455-?. I think the last letter is an A.
My questions are:
Why the two 5R4GY's?
Why the relay?
What is the C-455-A?
Any help would be great.
Thanks!
Tom
My "cult-like" following is accepting applications.
Old 2nd October 2010, 05:35 AM   #2
mctavish is offline mctavish  Austria
Hello, nice amp! That Peerless C-455 is a power supply choke The two rectifiers will handle more current, drop less volts, and have a lower output impedance than just one, I believe. Plus two always look cooler for sure! The relay is either for a B+ delay for the amp to avoid an over-voltage situation on the caps or for power to another accessory in what looks to be a console from the pics. Thats some nice iron and some old-nasty-dried-up electrolytics. Be wary of powering-up this one without a re-cap (speaking from experience) or you risk toasting your nice transformers. Hope that helps.
Old 2nd October 2010, 07:04 AM   #3
Originally Posted by mctavish View Post
Hello, nice amp! That Peerless C-455 is a power supply choke... Hope that helps.
Hi Mctavish,
Thank you!
A choke, Doh! I should have known that, but it seemed kinda big.
It's not a console, it's a Studio Monitor from WNBC television in NYC. It was built by the sound effects department.
It has a Western Electric 728B speaker.
Serial number two.
I wonder how many they made and when?
Thanks again.
Tom
Old 2nd October 2010, 08:42 AM   #4
SemperFi is offline SemperFi  Wake Island
Wow!
That's a keeper!!!
What year is it from?
Old 2nd October 2010, 02:24 PM   #5
Eli Duttman is offline Eli Duttman  United States
The use of Noval tubes suggests late 1940s or early 1950s vintage.
Replacing all of the electrolytic caps., as previously mentioned, is ABSOLUTELY ESSENTIAL. Replacing the waxed paper signal caps. with 716P series Orange Drops is also a good idea. Check the Carbon composition resistors for drift and noise.
The 5R4 is directly heated and turns on almost as fast as "sand". That's reason enough to use the Amperite thermal delay relay. There's plenty of room inside to add a "standard", solenoid actuated, DPDT relay, which will greatly extend the Amperite's life. Replacing a dead Amperite can be a costly experience. The amp's designer did not have that concern.
I agree, it's a KEEPER. Constructed with reliability, durability, and maintainability fore front. If only America could do things like that now.
Eli D.
Old 2nd October 2010, 02:24 PM   #6
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Neat!
What's the rest of it look like?
se
The Audio Guild
Old 2nd October 2010, 05:35 PM   #7
Originally Posted by Steve Eddy View Post
Neat!
se
Thanks All!
Here is a video of it as found. Not my video.
It's from the guy I bought it from.
YouTube - 1940's RCA / NBC custom made Speaker System. One of two.
Old 2nd October 2010, 06:16 PM   #8
Steve Eddy's Avatar
Thanks!
You should get in touch with NBC and see if you can get more information on this thing. Might have some interesting history behind it.
se
The Audio Guild
Old 2nd October 2010, 07:28 PM   #9
ArtG is offline ArtG  United States
That's also an interesting looking loudspeaker! It's the first speaker that I've ever seen that has a pair of (what appears to be) lifting handles built into the frame. I wonder who the manufacturer was. It looks similar to certain Altecs of the time period.
Thanks for sharing this!
Old 2nd October 2010, 09:35 PM   #10
The giant casters and the base are integral to the design as well.
Ease of movement must have been paramount in the design as it weighs about 250 pounds and is 61" h x 35" w x 25" d.
It is very well built.
Would someone explain this amp to me please?Hide this!Advertise here!
Can anyone explain me this Loftin White amp? Giaime Tubes / Valves 40 25th February 2013 03:28 AM
Can someone explain Ohms when buying an amp? bentleybloke Instruments and Amps 3 13th June 2009 10:01 AM
Can some one explain me this amp? Tarzan Solid State 22 3rd January 2008 07:06 AM
Please explain what's going on? DAC2.0 & UJB1 & DVD player. Mikett Digital Source 0 4th November 2004 03:04 AM
Copyright ©1999-2017 diyAudio
