| diyAudio Sponsor | ||
Dear folks,
I search for a solid state based PSU schematic for stabilized HT of +250V with max 15mA load. Input is ~325V. It should be "silent" means high ripple rejection as possible and as best safe against shorts on output. I want to use this for a small projet to supply only one tube ( ECC82 ) in a small case. As transformers I want to use two EI 38/16 connected against each other. The "middle" voltage of both transformers I want to use to supply the filament. First unchecked choice was an TL 783 based one. But after reading some threats about this quite old knob I rejected this. I found a few schematic using MOSFET as a linear regulator but this need lot of external parts for a good ripple rejection and stability. The "dream" is to get something like an µa78XX for 250V Does someone of you good fellows know an schematic which fulfil my requests? Thanks a lot! Karsten |
#3 |
Somebody already dreamed it...
http://www.supertex.com/pdf/datasheets/LR8.pdf |
#4 | |
#5 | |
The datasheet is VERY incomplete- for example, there's no line noise/ripple rejection versus frequency data. And load regulation is pretty mediocre. I'll bet their next generation of regs will be just what tube guys need.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#6 |
Salas simpler simplistic shunt reg.
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman |
#7 |
Hey SY,
THATS it! I never heard about this name before which might be the reason why I do not find the appropiate threads here... Thanks a lot! The tasks for this weekend are now save Best regards Karsten |
#8 | ||
#9 | |
MY amps are low noise and precise. Reasonably so, anyway.
#10 |
Hey folks, hey SY
Thanks a lot again for the help to find a HT PSU. Attached a picture of the result of your tips. Works fine at Uout 230V@5mA. I can´t measre any ripple Best regards Karsten |
| Recommended brands for tube HT psu caps | studiochap | Power Supplies | 8 | 20th August 2009 06:42 PM |
| 15mA 120V AC Power supply dessign | binspaul | Power Supplies | 4 | 11th May 2009 05:47 AM |
| Will this car sub be any good for HT? | Chicho | Subwoofers | 3 | 31st August 2007 01:00 AM |
| my SY CCS is only giving me 15mA | Shoog | Tubes / Valves | 17 | 6th March 2006 06:43 PM |
| Would this sub be any good for HT use | nuttinbutSQ | Subwoofers | 13 | 3rd January 2004 08:57 PM |
| Page generated in 0.10711 seconds (71.99% PHP - 28.01% MySQL) with 11 queries |
