Single tube, Single ended, 20W, impossible?
Old 3rd April 2012, 12:01 AM   #31
MelB is offline MelB  Canada
My that's some coincidence. I just built a GM-70 amp. Insanely nice tube. And very cheap. That's a hammond 18v 5 amp trans for it's filament supply. Ya 60 watts for the filament. It's just like a light bulb. This is my first iteration. Just using a Hammond 300-0-300 transformer gives me 810v on the plate. The power supply is designed for max 1200v though. I will switch in a 400-0-400v Hammond after some more testing. Should get about 1050v on the plate. I'm stopping there.
Old 3rd April 2012, 12:11 AM   #32
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I would put a mirror between tube and transformer. Too hot and too close.
The Devil is not so terrible as his math model is!
Old 3rd April 2012, 01:04 AM   #33
Adipocere is offline Adipocere  United States
No no no! That will just reflect the heat back to the tube's plate! The endbell won't be hurt by a little heat.
Old 3rd April 2012, 01:17 AM   #34
It's a lot further away than it looks in the other picture. It is not a problem at all.
Old 3rd April 2012, 01:18 AM   #35
Wavebourn's Avatar
It depends on how much is "Little". And how "cheap" is transformer for such an amp.
Old 3rd April 2012, 01:19 AM   #36
Wavebourn's Avatar
Sure, I see now how far it is, how anode is oriented, and how shiny is the bell itself.
Old 1st June 2017, 05:43 PM   #37
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Single tube, Single ended, 20W, impossible? Send a message via Yahoo to vdi_nenna
Is this tube capable of what you are asking? Maybe it requires a driver stage?
www.thetubestore.com - 6C33C-B Audio Tubes
I was once looking for the same thing. There's a Glass Audio article by Erno Borbely out there for a 15w SE with this tube, but I believe it's two stage. I have it if you'd like a copy.
PM me, if interested.
Vince
I build, therefore I am.
Old 1st June 2017, 07:32 PM   #38
davorin is offline davorin  Croatia
QE08/200 is good tube for ~20W output power in single end topology (A1).
QE08/200-D3a Se-ClassA-Triode connected
Old 1st June 2017, 07:34 PM   #39
211hojbjerg is offline 211hojbjerg  Denmark
Hi All,
in LA Vol. 8 you can find a 100W SE tube amp base on GU81 output tube. 0,02%@100W.
best regards
Karsten
Old 1st June 2017, 08:18 PM   #40
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Why would you revive an old thread and still not address OP's request fully?
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Single tube, Single ended, 20W, impossible?Hide this!Advertise here!
Single-ended mosfet-tube follower KlausB Solid State 44 17th May 2009 06:28 PM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
WTB: Single Ended tube amp bepatient Swap Meet 4 29th January 2006 08:11 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Copyright ©1999-2017 diyAudio
