Single tube, Single ended, 20W, impossible?
Old 18th November 2010, 12:02 PM   #21
kstagger is offline kstagger  United States
kstagger's Avatar
I was about to mention the EL156 in pentode, but see someone beat me to it.
I built an Shuguang EL156 ULSE amp with 450V on the plate, but never measured the output. It is an easy tube to drive - I used an EF86 in pentode. Plenty of power to run a pair of UREI 813A speakers.
http://www.mif.pg.gda.pl/homepages/f...28/e/EL156.pdf
Old 18th November 2010, 04:34 PM   #22
45 is offline 45  Italy
45's Avatar
I don't think EL156 with input step-up transformer will work well unless one has a beefy and mighty source. It's not a real solution, it's just shifting the problem from the driver to the source and usually it's just asking for more troubles......
It's that step-up the main problem.
45
Old 19th November 2010, 09:36 AM   #23
mik190 is offline mik190  Russian Federation
Originally Posted by coldcathode View Post
So that is an 833A with 2300 Volts on the plate?
WHOA!
Yes, I like this concept - only 1 element, but 2300V - is extremely high. At the moment I try to find something less energetic. But all other single tube variants are around 2W output.
Old 19th November 2010, 06:03 PM   #24
DolganoFF is offline DolganoFF  France
Send a message via AIM to DolganoFF Send a message via MSN to DolganoFF Send a message via Yahoo to DolganoFF
What's about this (sadly almost extinct) tube: EL503(EL530)
Plate resistance 7.5K
Transconductance 23 mA/V (!)
Plate dissipation 27W is a little small, but is 20W SE is an absolute necessity for you?
Old 2nd April 2012, 05:54 AM   #25
nuvistordave is offline nuvistordave  United States
Nearly 20 years ago John Atwater (of one-electron fame) had an SE shoot-out at his home in San Jose. The max power for most of the entries was on the order of 3W...But for the finale I set up my '13 Cubed' SE amplifier. 813's running into custom Doc Hoyer OPT's; 1300V on the plates and 2x SIXTY FIVE WATTS (130 watts total). Of course to spite the narrow minded group; the amplifier was all pentode; drive tubes were EF86's running 6AU5 cathode followers. The amps blew everything into the weeds with their premium OPT's and great circuit design. Later, Svetlana came out with the SV572 triodes. These beauties were good for well over 20 watts; the higher mu ones could easily do over 25 watts. Again, Doc Hoyer came up woth the output iron. I built several of these and sold them to fellow audiophiles.
Old 2nd April 2012, 10:05 AM   #26
revintage is offline revintage
A Schadeoed EL156 with a depletion mosfet at the input ala MJK would probably do it with acceptable fidelity.
Old 2nd April 2012, 02:09 PM   #27
FullRangeMan is offline FullRangeMan  Brazil
FullRangeMan's Avatar
I surprised no one mention the 805, more rugged than the 211/845 tubes as the 805 plate=125W, and gain is 50 with the same 900V from 211(gain=12) and 845(gain=6), all this for the same sale price.
Howeber these 3 tubes need a driver.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 2nd April 2012, 02:23 PM   #28
Originally Posted by mik190 View Post
Here is the single tube single stage 45W amplifier.
http://spbsound.narod.ru/SPbSound/sc...chematic2.html
I read that some people build it in Russian forums.
Some people in Japane did similar as well as I heard.
I would like to repeat it at less powerfull tubes but did not find the scheme.
WOW, this GM70 amp had a triple secondary output transformer!!... Very impresive, I wonder how it sound??
Any chance did you know the price of this GM70 Integrated?? ("МикроГМка")
http://spbsound.narod.ru/SPbSound/photo/photo7.html
Old 2nd April 2012, 05:15 PM   #29
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Does 10 of 4P1L in parallel count?
Output transformer will be peace of cake, and no lethal voltage required.
Also, B+ easy to stabilize.
The Devil is not so terrible as his math model is!
Old 2nd April 2012, 05:34 PM   #30
v4lve lover is offline v4lve lover  Netherlands
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
YL1260/1350 EL3010 crazy steepness
v4lve
Single tube, Single ended, 20W, impossible?Hide this!Advertise here!
Single-ended mosfet-tube follower KlausB Solid State 44 17th May 2009 06:28 PM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
WTB: Single Ended tube amp bepatient Swap Meet 4 29th January 2006 08:11 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Copyright ©1999-2017 diyAudio
