Idiots question on resistors. - diyAudio
Old 8th July 2003, 02:43 AM   #1
Wella is offline Wella  United Kingdom
Wella's Avatar
Send a message via Yahoo to Wella
Question Idiots question on resistors.
Hello people.
Im new to this forum so please be gentle (well i have been watching silently from a far for a while but now (due to being in need of help) have decided to come out from the bushes.)
I built myself a valve amp from kit a while ago and am now ust about to start tweaking it.
Ok the question. The circuit diagram from the amp i built (WAD KEL84) has a resistor i intend to change at
3K3 0.5W
Now I have worked out, please tell me if im wrong, that this means 3.3K i suspect that they put the K inbetween as to avoid missing a "." and causing great confusion.
But the 0.5W , Ok this means zero point 5 watts. But i cannot find zero point 5 watt resistors. Now is this important i asked myself. I found 3k3 2W and have even ordered some.
But can i use these??
Im also changing some 6.8K (or is that 6K8) 0.5 W resistors and have got 2W replacements for these also. If this is dependant on circuit diagram and the like then what else will i need to change,
Well i think ive wrote far too much just to ask a simple question
Thanks for any help guys. Im sure i may be a regular visitor here asking stupid easy questions.
Paul
Old 8th July 2003, 05:34 AM   #2
SY's Avatar
It's a common European standard to use the unit or similar symbol in place of a decimal point. You'll see caps labelled "6u8" which are 6.8uF.
The wattage is a maximum that the resistor is rated to handle, i.e., a half watt resistor can dissipate up to half a watt before being damaged. Half watt resistors are pretty easy to get, but you can generally use a larger wattage rating of the same resistance as long as it's not unexpectedly inductive (rare) and can physically fit (a higher wattage rating resistor will be physically larger).
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th July 2003, 12:31 PM   #3
Joel is offline Joel  United States
Joel's Avatar
"zero point five watt" is a 1/2 watt resistor.
Old 8th July 2003, 12:49 PM   #4
diyAudio Moderator Emeritus
Bas Horneman's Avatar
3K3 0.5W
YES, that is absolutely correct.
But the 0.5W , Ok this means zero point 5 watts. But i cannot find zero point 5 watt resistors. Now is this important i asked myself. I found 3k3 2W and have even ordered some.But can i use these??
YES...No problem
You don't have to change a thing, like SY said it can handle more heat.
PS. Not to keep you from doing it. But chances are you won't hear a difference.
Another PS...Be careful of high voltages. The caps can hold their charge quite a while.
idiots guide to impedance + spdif measurement woodturner-fran Digital Line Level 7 20th October 2008 07:04 PM
question about resistors. scampo77 Car Audio 3 14th September 2008 05:15 PM
Quick question about resistors Ryssen Parts 0 18th January 2004 05:55 PM
Copyright İ1999-2017 diyAudio
