Old 14th November 2010, 02:04 PM   #11
MikeV is offline MikeV  United States
>>>I’m interested in getting Edcor to make an opt for 6P1P/-EV and 6AQ5<<<
So what's the consensus? Does Edcor have a transformer ready to go for my PP 6P1P's (or 7C5's) ??
Should I look at the GXPP's like this one GXPP15-8-10K
what about Ken's suggestion for the 10 watt CX model?
or should we lobby for a custom wound like the OP suggests?
thanks for your input!
Old 14th November 2010, 10:46 PM   #12
Miles Prower's Avatar
I'd say fuggeddabouddit. PP 6AQ5s sound pretty good running open loop. This type doesn't make nasty higher order harmonics that require the extra help of local NFB. Types like the 807, 6L6, other 807-oids, make more higher order harmonics, and so need local NFB to get them sounding good.
Just use the 6AQ5 normally, preferably with a regulated, Lo-Z, screen supply, and add just enough gNFB to take the edginess off.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 12th July 2011, 04:00 PM   #13
7n7is's Avatar
Transformers having cathode windings have been used in some McIntosh amplifiers and Hammond PR40's. I bid on a couple Hammond PR40 amps on Ebay, but haven't won any auctions. I was thinking of converting one of them into a stereo tube amp.
Audio Tube Amp Schematics
http://www.captain-foldback.com/Hamm...R40_QR40_1.gif
Old 12th July 2011, 04:18 PM   #14
7n7is's Avatar
This looks interesting.
A Kenneth Olson 100W Audio amp
Old 30th October 2011, 12:20 AM   #15
ppl is offline ppl  United States
ppl's Avatar
I have a Push pull Ultra linear output stage with cathode feedback using the Hammond 1650 series of output transformers. if you use these connected up for 16 ohms and ground the center tap you will get balanced AC voltages from ground to ether winding end that is connected to the cathode. Works well
Dynaco A-440 pair FS dshortt9 Swap Meet 1 4th July 2010 05:32 PM
schematic request for transformer with 4k primary and UL taps junklocator Tubes / Valves 7 26th April 2010 05:12 PM
Using different transformer taps for each needed B+ boywonder Tubes / Valves 3 10th March 2010 09:59 PM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 12:37 AM
help on ul transformer please arex Tubes / Valves 29 19th June 2005 03:58 PM
Copyright ©1999-2013 diyAudio
