| diyAudio Sponsor | ||
Soakin' up the Sound!
A coworker brought me this Westinghouse Canada Model 511 radio today. I mentioned in a conversation a couple of weeks ago that I had an interest in tube amps. He has been collecting them for several years and said he had one that he would give me if I wanted it. Cool! Of course I accepted his charity. So today, sitting in my chair when I came in my office was this beauty.
It powers up and even receives a station or two. The sound is very scratchy. Even walking across the floor near it causes some scratchiness in the sound as the floor vibrates. When I move the tuner dial, VERY scratchy. It's got 3 bands: SP, MU, P.B. I'm at a loss about these, except I know one of them is AM. It's also got a volume and tone control. So, I'm not sure where to start. I'd say the volume and tone control need De-ox'ed and Faderlubed. The tuner needs cleaned, so I suppose that should be next. And then a recap. Somewhere along the way, the bulbs around the tuning scale need replaced too. Can anyone tell me about this radio? Any advice or suggestions? I can use all the help I can get! Thanks. Mike
#2 |
I never look a gift horse in the mouth.
Sweet looking radio. well worth cleaning up and restoring. |
#4 |
Thanks!
#5 |
Wow, does it receive stations without antenna connected? Great!
I would start from replacing filter capacitors. Leave old high cans as is, just unsolder wires from them and put under the chassis a couple of modern caps, they are much smaller in size. Second, you need to clean a variable capacitor. Most probably some dust between stator and rotor plates caused it to be scratchy. Or sliding contact that grounds the rotor is dirty and oxidized. Then remove all paper was capacitors and solder instead of them modern film capacitors. I suggest you to do everything one by one. You may check also values of all resistors, carbon comp resistors of such an age usually drift a lot. Then you will need to align it carefully. For the beginning, don't touch IF tuning slugs. Just tune it to the highest frequency (rotor plates off the stator), then carefully adjust trimming capacitor in input selector tank (don't adjust the trimmer in heterodyne can!) by maximal loudness.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#6 |
I may end up with a Philco Chassis 89 receiver from my DIL who needs money. I'll end up paying more than it is worth to help her out. I did some research on it and there are lots of web sites dedicated to restoration of old radios.
Take your time and do some studying before you start restoring it. It will pay off in the long run. |
#7 |
I'm kind of a Westinghouse freak..
Want to do some trading for that radio?
All my battles have been won, But the war has just begun. |
#8 |
Lovely radio - much nicer than your usual ganky sheet metal console chassis. Treat it nice, and it will be a balm for both the eyes and the ears.
#9 | |
Mike
#10 |
Hope you get that thing back to 100%, it looks like a real gem!
There was a nifty guide for stripping the old cap cans down, and installing modern capacitors inside them to keep a full factory appearance, If I can find the guys site, ill shoot it your way! What tubes is it using?
| FS: 2 Tung-sol 45 tubes, 2 Westinghouse 5u4gb tubes | athos56 | Swap Meet | 0 | 3rd August 2010 11:18 PM |
| Let's see, what did we DIY today? | Magura | Parts | 7 | 5th June 2009 07:46 AM |
| westinghouse model 80 radio - eval for parts? | MichaelPublic | Tubes / Valves | 3 | 4th February 2008 01:19 PM |
| 2-matched brimar 12au7-1 westinghouse 6v6gt | RogerWilco | Swap Meet | 0 | 10th September 2005 06:28 PM |
| Page generated in 0.11825 seconds (81.43% PHP - 18.57% MySQL) with 11 queries |
