| diyAudio Sponsor | ||
What sort of tube is this ?
#2 |
Hey pjp
Well, looks like a tube :-) And the background shows that you have more than one of them... Karsten |
#3 |
I can't make out a lot of the internals but it looks like it has beam forming plates, so probably a tetrode. From the size and shape withthe top cap fpr the plate, I'd venture that it is made for high voltage >600V.
Power transmitter tube for HF maybe. Might be suitable for output tube, might not. No numbers on the tube or box? |
#4 |
Is it a vacuum relay? Or thyratrone?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#5 |
Would a vacuum relay have a plate like structure? The few I've seen do not, but I've only seen three or four vacuum relays.
#6 |
I recall venturing across a webpage about gigantic tubes, it was on one of those german websites, either Jogi's Roehrenbude or Burkhard Kainka's website I believe (I'm too lazy to check :P ).
The article was about one of those gigantic Kriegsmarine WW2 or thereabouts era tubes, it looked awesome, almost exactly like the one pictured but IIRC it had two glass protrusions rather than one (so not just anode but also access to another electrode via bulb rather than underlying socket pins).
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#7 |
High Voltage Thyratron
(Sorry for my bad english) Look at the top cap: No sharp edges, everything is round to avoid corona. The edge of the cap is folded back to the cap for corona protection. This tube was made for really high voltage. regards |
#8 |
[QUOTE=What sort of tube is this ?[/QUOTE]
Thats the Russian (GMI family) of high voltage RADAR modulator pulse tetrode tube.I use similar tube for midle power AM trasmitter long time ago. |
#9 | |
With your input and a bit of googling I think I now know what it is - a GMI-90 Beam Tetrode in its Socket. More pics here: 4hv.org: Forums / Projects / GMI-90 Project ideas |
#10 |
Wow! That tube is bigger than I thought. From the first picture I figured it was about 5" tall and 2-1/2" in diameter. I bet it is more like 10" tall and 6" in diameter.
You can get 40Ma at 30KV out of a Neon Sign Transformer, but I sure don't want to try working with it. 175W in heater supply alone means it will be a real power hog. |
| Nos Usb Das | Banfi T. | Digital Line Level | 4 | 5th August 2009 04:05 AM |
| Ist Post! Where to start? | feeblechimp | Multi-Way | 24 | 17th May 2009 07:32 AM |
| SONY DAS-702 schematic needed... | ALP | Digital Source | 7 | 22nd December 2007 06:37 PM |
| Page generated in 0.09478 seconds (78.07% PHP - 21.93% MySQL) with 11 queries |
