| diyAudio Sponsor | ||
I don't know if anybody has put this info out here yet, but thought I would share it. I was in the process of setting up a few CCSs for an up coming project and decided to collect some data while I was at it. I hope you guys find this usefull the next time you go to use the IXYS IXTP01N100D. These values will get you in the ball park.
Rgs, JLH P.S. The gate stop resistors are 220 ohm Allen Bradley carbon comps.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way! |
#2 |
Thanks!
Here is my result for testing a single device with 30V d-s. It looks like there is a substantial difference between your measurement and mine. Difference due to Vds being ~3V over the bottom device in the cascode vs. 30V in my measurement? |
#3 |
On my measurements, I varied the B+ from 75V to 220V and it made no difference in current. The cascode appears to be fairly immuned to changes in B+ supply.
Rgs, JLH
#4 |
Have you tried with 2 mA too? Is there any issue with such current value?
45 |
#5 |
#6 |
did you have Rset for LND150? can you post here please? thanks..
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
| Ixys 10m45s | theskintman | Tubelab | 0 | 31st August 2010 11:31 AM |
| IXYS N-Type MOSFET | serious_lee | Parts | 3 | 28th June 2010 09:50 PM |
| Whats up with IXYS IXTP01N100D? | Bas Horneman | Parts | 6 | 13th June 2010 03:51 PM |
| IXYS Bridges | raincheck | Pass Labs | 2 | 30th July 2004 01:32 AM |
| IXYS mosfets ? | woody | Swap Meet | 1 | 30th August 2003 06:25 AM |
| Page generated in 0.08603 seconds (72.01% PHP - 27.99% MySQL) with 11 queries |
