diyAudio Sponsor
Old 21st September 2010, 01:57 PM   #1
djn is offline djn  United States
djn's Avatar
Default How the heck do I solve this problem????
Hi All, I am building a RatRod amp with the 6LR8 compactron tube. As you can see by the pix it will be flat black and I will pin stripe it with white and red....just like a RatRod. Anyway, the two outboard holes on the front are for Oil Pressure and Oil Tempature gauges. How can I make those two gauges work as VU meters?????
Old 21st September 2010, 04:14 PM   #2
kevinkr's Avatar
Purchase a set of those round Chinese made VU meters that show up on eBay from time to time?
www.kta-hifi.net
Old 21st September 2010, 04:16 PM   #3
djn's Avatar
At first I was going to do that but then realized that this is a RatRod amp and it should have car gauges.
Old 21st September 2010, 04:20 PM   #4
kevinkr's Avatar
Most car gauges I am familiar with have hot wire mechanisms which probably have too long a time constant to work well for this application. (I could be wrong)
I think taking some meters and modifying them to look like car gauges would work a lot better.
I'd look at Stewart Warner's automotive electric gauges and see if they have anything that might work..
www.kta-hifi.net
Old 21st September 2010, 04:25 PM   #5
Arnulf is offline Arnulf  Europe
I don't see any red and white stripe
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 21st September 2010, 05:11 PM   #6
Michael Koster's Avatar
Get some round meters and make new dial scales for them marked "oil temperature" and "turbine inlet temperature" , "EGT", or whatever with green and red segments...
Meter - from Tonne Software
Michael
Old 21st September 2010, 05:25 PM   #7
Frank Berry's Avatar
You could purchase or borrow the Oil Temperature and Turbine Inlet Temperature gauges and scan the faces of the gauges. Glue the scanned images to a couple of VU meter movements.
As for connecting the VU meters, all you'll need is a bridge rectifier (using Schottky or Germanium diodes) fed from the secondary side of your output transformers and a 1k pot so that you can adjust the sensitivity of the meters.
Please share a photo after you have completed the project. It looks good so far.
Frank
Old 21st September 2010, 05:30 PM   #8
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Thank you Michael, nice software!
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 21st September 2010, 06:19 PM   #9
djn's Avatar
Nope, no stripes yet. I just now finished all the drilling and whacking and now taking it to Ron's for pin striping.
Thanks all for your suggestions. I really don't care for VU meters, I just thought that since I was messing with it, I could turn the car stuff into VUs. When I get the meters, I see what I can do but it sounds like it might not work as I'd hoped.
Old 21st September 2010, 11:48 PM   #10
taj is offline taj
taj's Avatar
Heck, I can draw up anything you can imagine. Let me know if you need a custom meter dial done up (nicely.)
Wavebourn, ... nice. :-)
..Todd
lets see if u can solve this puzzle sss The Lounge 1 5th October 2007 04:20 AM
Help me to solve my UcD400s Problem ncc Class D 8 3rd October 2007 07:21 AM
Crackle !! can't solve ?? titanchen68 Class D 29 7th May 2006 03:20 AM
Please help me solve the problem MlinarS Tubes / Valves 14 2nd June 2005 02:12 PM
Need help to solve potential imaging problem! jim_vt Full Range 9 11th May 2005 06:35 PM
Page generated in 0.10107 seconds (79.37% PHP - 20.63% MySQL) with 11 queries
