| diyAudio Sponsor | ||
Is this generic schematic of a long-tail pair phase splitter correct? Are there any additional parts (resistors or caps) that need to be added? I am using the schematic in a review. I drew it from looking at numerous variations on several websites.
John Johnson |
#2 |
You are missing the plate load resistors, and perhaps output capacitors. You are also missing grid stoppers, and the input cap may be optional, depending on the presiding stage. And I almost forgot, where is B+? (called Vcc by the vulgar)
By the way, that is not a long tail pair. A Long tail pare would have a negative supply. Idea is that the cathode resistor is very large, to approximate a CSS. HTH Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus Last edited by DougL; 18th September 2010 at 11:00 PM. |
#3 |
This is where I got most of the schematic for a long-tail pair phase splitter:
The Long-Tail Pair Is his schematic incorrect, or did I just leave something out of my own schematic? |
#4 | |
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#5 |
check out merlin's pages. Very easy to understand, and practical
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#6 |
Perhaps this one would be better to draw from (the schematic at the bottom of this URL):
http://www.angelfire.com/electronic/...Amp-Phase.html |
#7 |
nope - same issue identifed above by waveborn - thats a short-tailed pair...
The better one is this one
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 Last edited by aardvarkash10; 19th September 2010 at 03:05 AM. |
#8 | |
If you want a LTP with very closely balanced signals then probably a small pentode as the current sink is best.
I am just about to try this but with a SV83. EF86 is described below. Quote:
#9 |
or, for ultimate ease - a sand CCS. 317 anyone?
#10 |
Thanks much. I will probably use the layout that aardvarkash10 illustrated.
| Long Tail Pair Linearizer | Electrone | Solid State | 17 | 21st April 2009 02:25 PM |
| Long Tail Pair Phase Inverter with Penthode ? | Yvesm | Tubes / Valves | 4 | 7th February 2006 09:15 AM |
| CCS in tail of differential phase splitter | ray_moth | Tubes / Valves | 12 | 28th January 2004 04:26 PM |
| 5687 long tail pair | NickC | Tubes / Valves | 7 | 14th May 2002 01:04 PM |
| Page generated in 0.09270 seconds (85.13% PHP - 14.87% MySQL) with 11 queries |
