| diyAudio Sponsor | ||
as you know
the accurate sound of the Valves does not give a deep bass, never this Balanced buffer does not lose quality of your acoustic scene and Complete the soul finally adding a body to music
visit my best audio idea http://www.esafono.it/DACTONE.htm |
#2 |
Valves work fine down to DC, but transformers do not. Nothing you add after the transformer can change this.
#3 | |
What is the input impedance of the transistor buffer? Is the transformer a typical tube output transformer, or is it a matching transformer between stages? If it is a transformer at the output of a tube power stage with limited bass output that is what your buffer will have, limited bass. Where does the idea that tubes plus output transformer lacks a deep bass come from? Depending on the transformer 25 Hz to 20K Hz bandwidth is not uncommon (also not cheap). DT All just for fun! Last edited by DualTriode; 18th September 2010 at 06:17 PM. Reason: oops |
#4 |
It reminds me some popular in 1970'th power amps-plugins that had PS, output transistors, and trifilar input transformers. Such an amp driven by a boombox sounded very loud. But did it sound clean?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#5 | |
#6 |
the really transformer's 25 Hz to 20K Hz bandwidth depends of your load
also of your power level specific data and parameters often make us lose the overview best adjustement is move 10KOhm values to have Ic 2A @ 8 Ohm load (3A@6Ohm) so need a very big dissipator for each channel
visit my best audio idea http://www.esafono.it/DACTONE.htm Last edited by Stee; 18th September 2010 at 07:40 PM. |
#7 |
Yes, that's how we sold Mindblowers. We explained to people that their existing car stereo will sound better because it's not driving speakers, just the "easy load to drive" input of the Mindblowers, and the Mindblowers are doing all the work!
#8 |
in structural projects, there are two safety factors, static is third of dynamic.
in short I am arguing that the TUBES output transformers are undersized 3 times. I tried to shunt the secondary in parallel instead series (4 and 8 Ohm to 2 Ohm) ...improves but not enough. advantage of the buffer is to isolate the reactive power back from the speakers on the negative feedback of tube. you do not have large heat sinks may adopt a bias AB1 (0.5 A) in this case it is better to use identical components with gain (gain means speed) I found the same gain (Hfe 100) with A1302 and C5200 two generations who marry perfectly
visit my best audio idea http://www.esafono.it/DACTONE.htm Last edited by Stee; 19th September 2010 at 06:56 AM. Reason: add jpg |
#9 |
Which tube do you smoke today, Stee?
#10 |
| Tube Buffer? 12ax7? | wttaylor | Tubes / Valves | 10 | 24th February 2010 01:40 AM |
| Tube Buffer – question? | colinB | Tubes / Valves | 36 | 9th February 2009 09:13 PM |
| tube buffer values | trancy | Chip Amps | 12 | 29th February 2004 11:09 AM |
| Tube buffer on TDA1543? | sparkle | Digital Source | 0 | 23rd February 2004 07:22 AM |
| Tube buffer | NickC | Tubes / Valves | 3 | 9th May 2002 11:20 AM |
| Page generated in 0.10063 seconds (82.27% PHP - 17.73% MySQL) with 11 queries |
