diyAudio Sponsor
Old 15th September 2010, 08:19 PM   #1
Empee is offline Empee  Netherlands
Empee's Avatar
Default RH84SE, use as headphone amp ?
Hi all !
I got a question;
I've got a new DAC (the super pro 707) and am now bypassing my onboard soundcard.
Now I'm not so sure of the soundquality, running my headphone directly out of the DAC.
The headphone I use is a Senn HD650, presenting an impendance of 300ohm
On my desk, there is a non-used RH84SE amp (build myself a year ago),
and I was wondering if I could use that amp as a headphone amp...
Do I need to rebuild it, or can I use some resistor L-pad on the 8ohm taps
to make it work ?
Please help me out!
Empee
In the end, all is good
If it's not good, it's not the end
Old 15th September 2010, 08:33 PM   #2
porkchop61's Avatar
I've seen Fisher receivers that have fixed resistors on the OT's to drive the headphones. I've been wanting to do this on one of my KT88 SET amps so I can have a headphone jack. I don't have any idea as to the value of the resistor, but the wattage is probably dependent upon the output power of the amp. I'd be interested in what more experienced builders have to say about this.
Glenn
"Imagination is more important than knowledge"
Old 15th September 2010, 09:00 PM   #3
Soonerorlater's Avatar
Appears to be the same on my Pioneer ER420 receiver which I'm stripping at the moment. Removed 100 ohm resistors. Power output is about 15watts per channel.
There is a speaker on/off switch on my amp which appears to dump the channels into 16 ohm resistors. This would probably be required by your RH84 SE as well
Might be more fun to make a dedicated headphone amp.
Old 15th September 2010, 09:42 PM   #4
Connect a 10 ohm dummyload to the output, and the sennheisers parallel to these!
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 16th September 2010, 07:38 AM   #5
Empee's Avatar
Default That simple...
Goodmorning y'all !
Is it really that simple ?
It sure sounds the way to go, but last thing I want to do is wreck my HD650...
I found this on the internet:
HeadWize - Headphone FAQs
But I do not see how the amplifier will see a "normal" load of 8 ohms that way.
Will try the 10ohm resistor trick tonight,
I think I got some 10W resistors lying around...
thanks for your replies !!
Old 16th September 2010, 08:23 AM   #6
Hi empee
Remember that almost all power produced by the amplifier will be 'wasted' in the 10 ohm load! A RH84SE will produce about 5W in an 8ohm load. That corresponds to an output voltage of around 6,3V RMS, as P = V^2 / R. Using the same formula it is easy to calculate that 6,3V RMS in the 300 ohms of the HD650 will result in a max power dissipation of about 0,113W. I can't find detailed specifications for the HD650, but I am quite sure they can handle it: probably your ears will suffer more than the cans
Erik
Old 16th September 2010, 02:47 PM   #7
Empee's Avatar
Default It works !!
Hi Erik,
It works !!
I only had a couple of 6.8ohm resistors
(50W mounted on heatsink, 12W unmounted)
But I figured most '8ohm' speakers are usually around 5ohms
so it works, but I now see (hear) I really need to re-work the powersupply.....
HUMMMMMMMMMMMMMMMMMMMMMMMMMMM
This might be the moment to decide to make a dedicated headphone amp.
Having said that,
I've got a pair of speakertransformers (originally meant for 100V speakers),
made by Philips, using the same core of the allmost legendary AD9058 output transformers.
Measuring them, I calculated that putting 300ohms on the secudairy,
I will get a reflected load of about 5.5K on the primairy.
What if I were to use these transformers in the EL84 schematic ?
Tubes in triode, to minimize output power ?
What's your verdict on this scheme ?
Greetz,
Empee
Old 16th September 2010, 04:46 PM   #8
Arnulf is offline Arnulf  Europe
100V transformers might not cope very well with DC across its primary, however if they are indeed 5.5K : 300R they must be very high wattage type so core is probably large enough to still stay in the linear region despite DC bias ? Try it out and let us know whether you're missing out on low tones (bass) or not.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 16th September 2010, 05:07 PM   #9
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
You can modify them to work in SE: disassemble and make an air gap using paper.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 16th September 2010, 06:04 PM   #10
Some 100V transformers I have are already built with same orientation (no spacer between both stacks though) and are welded together. "What welder hath joined together no man shall put asunder" I think that simplified the construction as interleaving requires more work.
2x Gain pure op-amp headphone amp idea Dxvideo Headphone Systems 30 10th September 2011 02:05 AM
FS: Millett Hybrid headphone amp / pre-amp and Tube power amplifier BuzzerBro Swap Meet 7 22nd June 2010 08:51 PM
HLLY HIGH END DMK-IV USB DAC Headphone AMP Pre-AMP hllyelec Vendor's Bazaar 19 4th January 2010 01:10 AM
OLT Headphone amp useing two EL84's & a 12ax7? ak_47_boy Headphone Systems 3 24th December 2006 07:58 AM
SDS Labs Headphone amp. Anyone built it? can it be converted to a power amp? JCoffey Headphone Systems 1 30th May 2003 12:11 PM
Page generated in 0.12030 seconds (83.28% PHP - 16.72% MySQL) with 11 queries
