| diyAudio Sponsor | ||
Just today I was thinking about my future amp project, a 45 direct coupled SE. Recently I found that diode biasing a triode (6C45's in a RIAA preamp) can be a nice thing. In the case of the 45, it would save a lot of money and inside space in the chassis, what with the size of large bypass film caps (I use Solen Fast).
So why not do it with a vacuum diode? A rectifier comes to mind - there are a number of relatively cheap rectifiers able to push thru the needed 40mA of current. What do you think, is this smart? Can it be done? |
#3 |
Please explain.
#4 |
Look at the V vs I curve for a 6X5, for example. The AC impedance is dV/dI, which looks like 250-300 ohms for that tube. Other high vacuum rectifiers are similar.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
Like SY said, impedance is a bear on most vaccuum diodes. I've experimented with it a little, somewhat promising results, as long as your diode drops the necessary voltage at the desired current. Finding a pair of diodes reasonably matched is the main issue. I wouldn't do it for SE, due to voltage drops changing during current peaks. On a PP amplifier it seems like it may be promising, although either way your basically using it like a hot resistor though. I dropped my experimenting and just started tinkering around with LED arrays instead. VR tubes however...
#6 |
I'm afraid I still don't understand what the problem would be? Please elaborate.
I've understood that class A circuits always draw the same current, so why would there be current peaks? |
#8 |
You mean that a vacuum diode wouldn't prevent regenerative feedback? Ah. Feeling a bit slow right now.
#10 |
So I guess I'm stuck with solid state diodes or larger than life film caps.
Well, thanks for clearing this up. |
| Advice sought on medium power triode for tube headphone amplifier | rjm | Tubes / Valves | 13 | 16th May 2010 04:05 AM |
| Power tube bias increasing with signal. | tubesrock | Tubes / Valves | 2 | 23rd July 2008 03:23 AM |
| metallized caps instead of electrolytics in a tube rectifier power supply? | jarthel | Tubes / Valves | 15 | 26th May 2006 04:46 PM |
| Bias the new power tube | TRAN TUAN KHANH | Tubes / Valves | 2 | 11th April 2005 11:33 AM |
| Page generated in 0.10353 seconds (79.88% PHP - 20.12% MySQL) with 11 queries |
