diyAudio Sponsor
Old 15th September 2010, 04:26 PM   #1
Default 25 watt output tube
I'm designing my first amplifier for my senior project in electrical engineering. Looking for suggestions for an output tube for 25 watts at the output stage.
Old 15th September 2010, 04:40 PM   #2
leadbelly's Avatar
Do you mean a tube with 25W plate dissipation, or a tube that can be used to build a 25W amp? What kind of amp: single ended or push pull, pentode or triode, etc.?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 15th September 2010, 06:49 PM   #3
A kt120 with 600v b+ in pentode SE would be the only sane thing i could think of. Lots of stuff if you want 18-25 watts in PP setup though.
Old 15th September 2010, 06:57 PM   #4
Globulator's Avatar
I'd use a GU50, then it doesn't really matter how much power you want from it: it will be enough.
Old 15th September 2010, 07:11 PM   #5
Frank Berry's Avatar
A pair of 6L6 tubes will easily produce 25 watts in PP AB mode.
Frank
Old 15th September 2010, 07:21 PM   #6
kstagger's Avatar
EL156 SE as a pentode can swing 24Ws
http://www.mif.pg.gda.pl/homepages/f...28/e/EL156.pdf
I've built a pair of monoblocks using single ended Shuguang EL156s in Ultralinear mode. Very good amplifier.
Old 15th September 2010, 07:27 PM   #7
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Sure. It is still alive even after short dissipation of 100+ watt.
Recently experimenting with monoblock with 4xGU-50 output I made a mistake in bias adjustment. However, it sounded very nice and very loud, but smelled like a burning paint, so I come closer to the amp to sniff what smells, I thought it was some resistor... But I found that anodes were red.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 15th September 2010, 07:38 PM   #8
Are you actually going to build it? If you are only doing a design, you can use the 6CA7 (EL34) pentode in push pull for an easy 28 watts. The reason I suggest this one is that you will have no problem easily finding datasheets on-line for this popular tube as it is still widely manufactured. Other such options include the KT88 and 6550 pentode with even greater power. Single ended designs are simpler but 25 watts pushes way out on the envelope and I suspect you will struggle to find datasheets on these monsters.
If you are going to build it, then that's another matter.
Old 15th September 2010, 07:45 PM   #9
piano3 is offline piano3  United Kingdom
Is GU-50 good for SE?
Old 15th September 2010, 08:05 PM   #10
Wavebourn's Avatar
Yes. 450V B+, 4K load, 620 Ohm cathode resistor shunted by capacitor. Needs about 100-120V of input swing. Input transformer may be used to drive by iPod or some other similar source. 100V to 16 Ohm speaker transformer may be good to drive it.
About 40W of idle dissipation, about 100 mA of idle current.
25 Watt 8 Ohm in Dynaco clone lineup Solid State 24 18th May 2009 03:54 AM
minus 25 on output mosfet amp Jan Deckers Solid State 3 12th April 2009 05:14 PM
Output tube for 600V B+, 5800 ohm primary PP, tertiary 25% UL taps? GordonW Tubes / Valves 7 8th August 2008 10:11 PM
Designing 4 channel ampli for Mid and Hi band using LM1875 or any other about 25 watt makarand_g Chip Amps 5 6th June 2007 02:08 PM
25 Watt Amp, 12Volts? silentblackhat Chip Amps 1 10th May 2007 10:32 AM
Page generated in 0.09223 seconds (79.02% PHP - 20.98% MySQL) with 10 queries
