| diyAudio Sponsor | ||
I am looking for replacements for KT61
I am aware that these are equivalent 6P25 / KT61 / CV1853 / 6AG6 / EL33 Any of the modern Russian Tubes suitable? These are for a vintage suitcase style guitar amp which runs 6J7 pentode into a single ended KT61 for 4.5 Watts out. Cathode bias resistor 100R for 40 to 45mA idle, at which operating point gm is 10.5 mA/V. (Va = 250V) KT61 are now VERY expensive - all of those TL10 owners must have snapped them up. Any hints gratefully received. Cheers, Ian Last edited by gingertube; 15th September 2010 at 03:49 AM. |
#2 |
I did not solve such a problem before, needs investigation.
Do you have a datasheet for KT61?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
Data
Heater voltage 6.3V Heater current 950mA Max anode voltage 275V Max screen voltage 275V Max anode dissipation 10W Amplification factor * 27 Anode impedance * 2750 ohms Mutual conductance * 10.5mA/V Capacitances Cge 17.5pF Cae 0.8pF Cag 1.2pF *: At Va=Vg2=250, Ia=40mA Octal Base Pin Function 1 n/c 2 Heater 3 Anode 4 Screen grid 5 Control grid 6 no pin 7 Heater 8 Cathode Application Data Class A S/E Va = Vg2 = 250V Vg1 = -4.4 Ia = 40mA Ig2 = 7.5mA S = 10.5 mA/V Rk = 90 Ohms (my amp has 100 Ohms) Zout = 6000 Ohms Pout = 4.3 Watts THD = 8% Best I could manage, problem I found in looking through my tube collection for a sub is the 10.5mA/V @ 40mA. I need that sort of sensitivity. Cheers, Ian Last edited by gingertube; 15th September 2010 at 04:55 AM. Reason: More readable data |
#4 |
Leaks still in using must be swapped to 6L6 or EL34 by now.
IIRC, only minor tweaking is needed (cathode resistor?). It's said the linearity of KT61 is superior than those replacements. I haven't heard myself, only seen once. |
#5 |
Ian, I believe the only current octal valve with that kind of transconductance is the EL34. However it's heater requirement of 1.5A may prove a problem in your amp. All other octals with similar heater current to the KT61 (6L6, 6V6 etc) have rather lower transconductance. Have you tried Evatco in Qld for a KT61??
#6 |
No such Russian tube were made, unfortunately. Did you try EL84 instead?
#7 |
#8 |
The first valve amplifier I ever made (about45 years ago) was a mullard 3/3 in which I replaced the EL84 with a KT61 and the EF86 with an EF36 (based on what was available). It worked fine. (The transformers weren`t to Mullard spec either).
Barry |
#9 |
Ian,
If it's acceptable to put in a noval-tube with a socket-converter: EL821/6CH6. It's a video beam-tetrode. Google for "EL821 KT61" and you'll find some claims that these valves have very similar characteristics. Sometimes you happen to find them very cheap as nobody seems to use them. Kind regards, Yves D. |
#10 |
Seems logical to replace this with a 6V6 as it was commonly used in a lot of SE guitar amps, and no it probably won't sound exactly the same as a KT61 and you will need to change the cathode resistor to 270 - 300 ohms, otherwise it will plug straight in.
Transconductance unfortunately is somewhat more than just half that of the KT61.. (I actually just built a 6J7/6V6 SE stereo amp so it is fresh in my mind)
www.kta-hifi.net |
| *PING* Tubechimp | Geek | Tubes / Valves | 16 | 14th September 2010 05:18 PM |
| Ping EC8010 .... | moray james | Analogue Source | 15 | 22nd April 2009 07:09 AM |
| Ping ezkcdude. | G | Digital Source | 0 | 28th February 2009 05:20 PM |
| ping Scottmoose | Andrewbee | Full Range | 5 | 20th April 2006 07:07 AM |
| Page generated in 0.10186 seconds (78.94% PHP - 21.06% MySQL) with 11 queries |
