diyAudio Sponsor
Old 15th September 2010, 12:12 AM   #1
jasonguitar's Avatar
Default EICO 666 meter needle moves too fast/pegs too hard...help?
Any tips on slowing down/taming an unusually fast, hard pegging meter needle that otherwise calibrates and reads accurately? It just moves way too rapidly and when moving to full deflection and/or back to zero it overshoots/pegs way too hard. I have a perfect working 667 and it does not exhibit this behavior. I have already done the diodes across the meter mod on both units. Thanks!
Old 15th September 2010, 01:11 AM   #2
Sorry for the double posts guys. My computer crashed when I hit the "post new thread" button so I re-wrote this and posted it here not realizing till now that my original post had published.
Old 15th September 2010, 01:23 AM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
An electrolytic capacitor in parallel with the meter head is usually used to slow it down. Do you have a schematic?
Edit: I've found the schematic, no electrolytic there. Looks like a different type of head, if it measures well?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 15th September 2010, 01:58 AM   #4
It is a stock meter for this specific unit. I would think if it were different spec or damaged it wouldn't give me accurate readings but it calibrates perfectly and when testing the same tube with same approx settings on both the 666 and 667 I get the same readings. It just moves so danged fast!
Eico 666 meter movement speed help jasonguitar Tubes / Valves 1 15th September 2010 01:11 AM
Eico 666 tube tester original PANEL METER for sale in fair working/cosmetic condition jasonguitar Swap Meet 0 13th August 2010 01:00 AM
Eico 666 (satan's choice) tube tester help. Runco990 Tubes / Valves 41 13th August 2010 12:58 AM
Eico 666 tube tester restoration - need grid control! jasonguitar Tubes / Valves 4 9th July 2010 01:00 AM
EICO 666 tube tester - What settings do you use? rotofluid Tubes / Valves 4 1st August 2009 01:15 AM
Page generated in 0.07763 seconds (66.34% PHP - 33.66% MySQL) with 10 queries
