diyAudio Sponsor
Old 14th September 2010, 12:02 PM   #1
Default What makes is stereo?
Hi
Iam currently reading about tube amplifiers and the technology behind it. I have read several manuals and walkthroughs for different kinds of amplifiers but it is one question that i never get answered. It might be a really stupid question but i need a answer for it before i can understand the whole process. What is it that make it a stereo amplifier? first i thought it might be because of the amount of tubes. That in a stereo set both LEFT and RIGHT is treated as mono channels and is amplified separaty. But now i have now seen amplifier with one tube that still have stereo. Can someone explain this for me?
Old 14th September 2010, 01:40 PM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Stereo by definition is two channels, Left and Right. The left and right channels drive the appropriate left and right speakers.
This allows for spatial intrepretation of the sound.
If bridged it is no longer stereo.
Can you post the schematic of the one tube stereo? or a link to it?
Old 14th September 2010, 02:04 PM   #3
Right now i do not have any complete schematic, iam still working on it. So, with other words, if i only use ONE tube I can only get mono?
Old 14th September 2010, 02:11 PM   #4
This might not be the one I will build in the end but it is still a good example. Will I get sterio via this schematic?
Old 14th September 2010, 02:20 PM   #5
Merlinb is offline Merlinb  United Kingdom
Originally Posted by freestream View Post
Hi
A single glass bottle can contain two individual valves (or even more than two), so stereo is possible.
Old 14th September 2010, 02:30 PM   #6
So a tube like 572B that have 4 pins does only have one valves? so to find a tube with more then one valves i should look for a tube with more than 4 pins?
Old 14th September 2010, 03:05 PM   #7
Soonerorlater's Avatar
If you really must make a stereo amp from one bottle then why not look at this one Vacuum tube audio amplifier : DISCRETE SEMICONDUCTOR CIRCUITS
No apologies, that would only give you a mono amp.
Old 14th September 2010, 03:24 PM   #8
TheGimp's Avatar
The 572B is a High Mu triode, directly heated, similar to 811A.
You will need more than that to make an amp. It is suitable as an output tube and might work well in a SET (Single ENded Triode) amp. However, it is a High Voltage tube and I would not recommend making anything with it unless you had a lot of experience.
Danger High Voltage can be lethal!
Old 14th September 2010, 03:40 PM   #9
DF96 is offline DF96  England
You could use ELL80 or 6360 (=QQV03-10). But why?
Old 14th September 2010, 04:25 PM   #10
Thanks guys now i think i got the hang of it. If i understand it right i should first settle for what tube i want to use and from that choise make a fitting schematic.
Right now i just have a mental image of how i would like to desin the amp. I am a big fan of the big tube, like the size of 572B. I whould like to build a stereo amp (not just a pre amp, it should be strong enough to be standalone and power 2 speakers) with just 2 big tubes. If 572B is a bad choice due to it is High Voltage tube, do any of you know a big tube that is not High Voltage but can still amplify a grate deal?
Novice stereo subs project with stereo amp. PJeff Subwoofers 70 28th August 2011 06:48 PM
Stereo in/multiple Stereo outs Circuit MartinByrne Everything Else 3 7th May 2009 01:11 AM
Reprocessed for stereo, Rechanneled for stereo and Duophonic oldheathkitphil Analog Line Level 3 29th February 2008 01:20 PM
2 Stereo in's, 2 Stereo out's, USB DAC djd4n Digital Source 13 28th August 2004 02:23 PM
What makes a good Car Stereo cbosek Car Audio 4 11th November 2003 02:50 PM
Page generated in 4.52541 seconds (2.47% PHP - 97.53% MySQL) with 11 queries
