diyAudio Sponsor
Old 13th September 2010, 09:04 PM   #1
wrenchone's Avatar
Default 6B4G / 6S4S Biasing Question
I'm looking at doing a push-pull amp using 6S4S triodes and some Electra-Print output transformers. All of the circuits I've seen so far use cathode bias. Is theere any fundamental problem with using fixed bias if the bias source is low impedance? I was thinking of using source followers to drive the grids. I expect I'll get the usual snarky remarks about polluting the vacuum's precious bodily fluids with nasty silicon, but is there any real objection to using fixed bias with directly heated triodes? I'll be using some homebrew SMPS circuits to heat the filaments.
Old 13th September 2010, 09:25 PM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I would use them in PP with 350V on anode and -70V negative bias on grids, 15K P-P load. Should sound very nice.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 13th September 2010, 10:19 PM   #3
wrenchone's Avatar
The transformers I have from Electra-Print are 3k units.
Old 13th September 2010, 10:28 PM   #4
Wavebourn's Avatar
Hmmm...
Old 13th September 2010, 11:53 PM   #5
wrenchone's Avatar
Well, the original owner of the transformers intended them for a P-P 2A3 application. Right out of the RCA data sheet you get a set of design values that run the 2A3s at -60V fixed bias, 300V, 40 mA/side, about 140-150 ma peak current, 3k plate to plate load, 15W output. There we go... With the source followers I could go AB2 if I so wanted. A answered my own question, so it seems.
Old 14th September 2010, 12:03 AM   #6
Wavebourn's Avatar
Right.
My aim was on a clean 10W in AB1 on the edge of max allowed voltage.
Old 14th September 2010, 12:17 AM   #7
wrenchone's Avatar
Maybe so, but I want to work with the transformers I have on hand, especially as I got the pair of Electra-Prints for 'prox 1/2 the price that Jack charges for one piece these days. My other option would be some 6k Fisher transformers (I seem to be awash in them these days, as I've been compusively grabbing Fisher tranformers on Fleabay).
Old 14th September 2010, 12:28 AM   #8
Wavebourn's Avatar
300V 40 MA may be fine for 6K load as well.
Old 14th September 2010, 12:34 AM   #9
45 is offline 45  Italy
45's Avatar
The source follower is a very good idea. I am having great results in a 45's PP. The best driver so far....IMHO.
With those 3K OPT's I would suggest 250V/60mA, true 8 ohm speakers and it will be fine (will sound!! ). Using a classic 6SN7 cathode follower I remember I got "only" 14W at low THD. With the SF maybe it could be more (depending on how you make it....).
Old 14th September 2010, 12:55 AM   #10
Wavebourn's Avatar
With 3K OPT you will probably get "That vintage sound"
By the way, what are max grid current specs for either 2A3, or for 6С4С? It seems to me I have not seen them...
cathode biasing question puginfo Tubes / Valves 7 3rd June 2009 03:24 PM
6A3/6B4G/6S4S(2A3/2S4S) project widowmaker Tubes / Valves 20 31st May 2009 08:39 PM
6C4C - 6S4S - 6B4G op points? danFrank Tubes / Valves 2 6th December 2006 06:51 AM
question about biasing jsteigs Solid State 2 21st February 2005 12:10 PM
PP 6B4G stereo amp filament question BHD Tubes / Valves 6 18th June 2004 10:22 AM
Page generated in 0.11367 seconds (78.37% PHP - 21.63% MySQL) with 11 queries
