Center tapped choke loading - diyAudio
Old 5th July 2003, 06:00 PM   #1
Default Center tapped choke loading
Hey-Hey!!!,
I asked this question elsewhere, and got no satisfactory answer. I have a PP driver stage, triodes, common cathode, with both grids driven with signal form the phase splitter upstream. The stage is loaded with a center tapped choke. What sort of load does this pair see? I got answers from a fourth of the choke's inductance( half the turns ) to the whole thig plus things like the other troide's plate resistance.
Can a few of you help me sort this out?
regards,
Douglas
the Tnuctipun will return
Old 5th July 2003, 10:27 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
One tube will see 1/4 the end-to-end inductance, because L is proportional to the square of the turns; but since there is another tube effectively in parallel, helping it out, each tube sees only 1/2 the inductance. Thus for a 5k reactance at 20Hz, it must see about 40H, so the total choke must be 80H.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 6th July 2003, 12:59 AM   #3
diyAudio Senior Member
fdegrove's Avatar
It's not any different from a PP OPT really.
Think of it as a see-saw operation for AC-PP and it should become clear to you.
Frank
Old 6th July 2003, 03:04 AM   #4
well,
it seems as if you didn't look into the responses you received on the asylum, so why not build the circuit and tell us what happens... all you need is: the load, the Rp, and the -3db point and you will know the answer.
i'll say it again... the load seen by each common cored inductively loaded class A pp triode is 1/2 the total load seen by the pair. this assumes linear devices with no losses, it is the ideal, and in audio its what we strive for.
and before this gets out of hand... inductance is but part of the load in the class A pp pair.
dave
Old 6th July 2003, 03:15 AM   #5
Hey-Hey!!!,
I read every single one, and the refrenced links. There were as many differnet answers as answers posted( almost), not too mention the rest of the responses.
So I asked again. I can see what is going on with the circuit, that's why I'm building it( and having it built). I wanted a closed form way of looking at what is going on.
All in all, I am glad to see there are folks who are willing to help me see what is going on.
regards,
Douglas
Old 6th July 2003, 08:08 PM   #6
Joel is offline Joel  United States
Joel's Avatar
Is the center tap grounded?
As they said above, each grid sees 1/2 the total winding, obviously. How could it be otherwise?
Old 6th July 2003, 10:59 PM   #7
Hey Joel,
It's not a grid choke( said with Austrian accent ). The inductor is for an anode load on a PP driver stage. Either 2x 12B4A, 6CK4 or single 6BX7, 5687, 5998A...balance additionally assisted by CCS in common cathode load.
Here is part of that which is making question marks in the air over my head when I think about this. If I hook up the grid circuit( of the power stage) to each end of the choke and leave off one of the triodes, I will still get some signal to/out of the hanging end of the choke, right? So, put in the triode, feed it a signal as perfectly out of phase with the one going to the other end of the coil and what sort of load do they( the triodes loaded by the choke) see?
While I am fairly good at actually making the PP amps sound good knowing exactly how they work is another thing entirely...
regards,
Douglas
Old 7th July 2003, 12:17 AM   #8
fdegrove's Avatar
Ha...knowing the theory is one thing...putting it to practice is quite another isn't it?
Shall I conclude: reality sux?
Frank
Old 7th July 2003, 12:49 AM   #9
nah, you have got is backwards, reality is easy, theory sux. That's why there are more mechanics than engineers. The great mechanics I have gotten to know would have made brilliant Engineers, had they been able to stand the teaching of theory !!!!
regards,
Douglas
Old 7th July 2003, 10:46 AM   #10
Sch3mat1c's Avatar
A combination of your two - theories - is reality.
First of all, in theory, the free end of the choke will follow the other end, of course with an opposite polarity; however, in practice, loading, leakage inductance, DC resistance and parasitic capacitances will plauge the end result. Also it depends on the current capacity of the choke; if it can handle DC, then it will still function well enough, but if it can't and needs a balanced current instead, then all you'll get is distortion. LL and DCR vs. load contribute to reduce the free end's voltage output, while C will resonate with the LL, causing a resonant peak at some frequency, and a steady roll-off beyond that.
Tim
Choke loading vs. SRPP HVfanatic Tubes / Valves 3 29th January 2009 07:43 PM
Pentodes and Choke Loading ianc13 Tubes / Valves 8 12th August 2008 10:26 PM
center tapped choke inverter alexg Tubes / Valves 48 9th July 2007 12:45 AM
Two Transfomers => Center Tapped? Myren Analogue Source 6 12th April 2004 03:22 AM
Copyright 1999-2017 diyAudio
