#21 |
Also, if you can get 275V supply you could go for back-bias just using a 220 ohm resistor between the first and the second PSU capacitors. The cathode of the second cap is grounded while the cathode of first cap and the bridge are leaft floating. With the full current of the amp flowing through that 220 ohm resistor (say, 100 mA) you will get apprx. your 250V anode voltage and enough bias to play with.
Another solution could be 7x1.5V batteries in series. Cheers, 45 P.S. All the 6V6 I have, when put on the Hickok 539C as from manual hit the top of the gm scale at 6 mA/V and in some cases I must switch to 15 mA/V scale...!!! Last edited by 45; 14th September 2010 at 11:07 AM. |
#22 | |
The amplifier is actually running and largely complete - I will replace the 200 ohm resistor in the supply with a choke as I need more ripple suppression. Any other changes will focus mainly on improving the driver stage, feedback implementation and concerns about stability. I may ultimately spring for a better set of OPTs - these are very good, but I suspect I need more primary inductance because of the relatively high rp of the 6V6 even with primary side fbk applied. Mostly I need to calm down and do some measurements.. ![]() My 6V6GTs are U.S. made 1940s vintage Kenrad and NU (National Union) and may differ significantly from modern (foreign) production. They are very close to the stated conditions in the RC-12 tube manual when running at 250V and effectively -12.5V of bias. I have a Hickok 539B.. Very nice tester..
"Extraordinary claims require extraordinary evidence." - Carl Sagan Last edited by kevinkr; 14th September 2010 at 03:55 PM. |
#23 | |
(triode fanatic here) but you never know until you try. 6J1 sounds good in triode mode, don't know about the 6J7 - in case you want to triode connect that one later.
#24 | |
) and a pair of Sylvania VT-107 1940's coke bottle and grey glass.The Europeans test the same, they are Italian Fivre 6V6GT with black glass from the early 70's. They have a slightly bigger bulb than the American versions but it is just this production. In fact the older 1950's type was very close to the RCA in every detail... All these test around 5.5 to 6 mA/V and 40-42 mA. Then I have some Russians which test unusually strong up to 7.5 mA/V at 45 mA! Cheers, 45 |
#25 | |
What I am hearing is much better in some ways than I expected, but there are also significant audible deficits. As always a bunch of trade-offs are involved. It is certainly very dynamic and punchy in a way that belies the low power rating. Detail, imaging and depth would all fit the exceptional category. Tonal balance tends to the hard, almost but not quite solid state sounding end of the spectrum. Bass is insufficient, but what there is sounds right enough. It is a little pushy on some material, and fatiguing to listen to on others. (In fairness that particular material was not much better sounding with an all triode amp.) Makes me think that combining the colorations and strengths of the two might be a winning combination - combining strengths and offsetting weaknesses. Something I will look at after I complete the next amp which is a IT coupled GM70.
"Extraordinary claims require extraordinary evidence." - Carl Sagan Last edited by kevinkr; 14th September 2010 at 05:18 PM. |
#26 | |
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#27 | |
![]() By the way, 6J7 and 6SJ7 are very nice long forgotten tubes. 6П6С is a fair 6V6 copy, but has wide spread of parameters like all Russian tubes.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#28 |
They sound fine. As a power tube I have only listened to guitar amps. In HiFi equipment I have once listened to a fully battery operated preamp of a friend of mine! In fact you can run them nicely at very low plate voltage. That worked at around 30V in triode connection (bias about -1.5V for 3.5 mA) 10K load (LC coupled).
Cheers, 45 Last edited by 45; 14th September 2010 at 06:56 PM. |
#29 | |
Then I bought one of Pete Millett's red boards. It contains NO TRIODES, none, nada, zip. I can't stop playing with it. It just rocks better than most other amps. Of course I have hot rodded it into stratospheric power levels (250 WPC) but it sounds great as delivered. It is a different sound than a SET for sure, but a welcome change especially for loud or dynamic music. Don't dismiss the pentode until you try it for yourself.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#30 |
My first Pyramid amp used triode input, triode Concetina splitter, double triode LTP driver, pentode output.
Second version used pentode-triode (pentode input, triode Concertina splitter), triode LTP driver, pentode output. The last version uses almost all pentodes: pentode input, triode Concertina, pentode LTP driver, pentode output. No difference except optimal amplification factor between all 3 versions. All sound as very good PP amps.
| Simple SE with CCS and fixed bias | boywonder | Tubes / Valves | 0 | 21st February 2009 04:40 AM |
| Finding bias point in PP fixed bias | beamnet | Tubes / Valves | 14 | 7th December 2008 01:25 PM |
| Battery grid bias to fixed bias in Toccato? | w00t | Tubes / Valves | 3 | 2nd December 2007 12:34 AM |
| Odd's n Ends Revisited 6V6 SE amp | Sparky OR | Tubes / Valves | 2 | 10th March 2006 06:54 AM |
| turning a SE 6v6 to a 6bq5 amp | rvas18 | Tubes / Valves | 25 | 8th January 2004 06:29 PM |
