Old 13th January 2013, 09:22 PM   #31
I thought it was rather detailed already...
Anyway, attached is the schematic of my test common-cathode stage. The output goes to a 100 times amplifier with an NE5534A. The output of the NE5534A goes to a line input of an Asus Z9200U laptop computer and to an A-weighting filter, the output of which goes to the other channel of the laptop line input. The processing done with GoldWave and Excel is already explained in this thread. See also Linear Audio September 2012.
Old 14th January 2013, 08:51 PM   #32
MarcelvdG,
thanks for your answer. I'm thinking about to make (one more time) a noise measuring set-up, but this time, in a more "permanent" basis.
I have done a well power supply for one of my phono stages, and a pair of Linear Technology LT1115 op amps, that have a very good noise figure.
For measuring purposes, my National VP-7720A could be very suitable.
Cheers !
Old 15th January 2013, 04:24 PM   #33
In the meanwhile, I have attached a picture of a module that I have built some years ago, and I will use it again, for my "noise-measurements-set-up".
This module have 3 selectors for the gain: the central one have 5 position: 40, 45, 50, 55 60 dB and acts simultaneously for the two channels. The other two selectors, acts one for the left channel and the other for the right one. In this case, they have 4 positions with increments of 1 dB. (0, 1, 2 and 3 dB). This technique is very useful for to use it as "balance" control, for to compensate differences between channels in some cartridges.
Anyway, I will use this module as "noise amplifier". (using only the op amp stage)
cheers!
Old 15th January 2013, 06:49 PM   #34
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by Wavebourn View Post
For low microphonic I have some other missile-rocket-science tubes. I won't name them, because I am going to buy supply for myself, then reveal all details.
Here you go:
planar triode 6S17K-V with 8 micron grid.
gm = 14 mA/V, mu = ~150, designed for 10 g vibration, or up to 500 g acceleration.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 15th January 2013, 07:15 PM   #35
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Yep, tested it. A great tube indeed:
http://www.diyaudio.com/forums/3029622-post.html
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 15th January 2013, 10:10 PM   #36
Wavebourn's Avatar
Originally Posted by mogliaa View Post
Yess, a killer front-ed tube for microphone and phono preamps!
The trick is, the grid is so close to cathode so it better works with input transformer, and biased by grid leak resistor and own input current, while cathode firmly sits on the ground.
Old 17th January 2013, 07:20 AM   #37
Now, I just have finished to put the power supply into a decent box. Now, I will build some sort of shielded container for the circuits and the "Device Under Test" (DUT). I have not idea how to do it until now, but I will found some cheap solution.
By the way, I'm thinking to use LabView for to make all the signal (noise, actually) analysis and presentation, but I'm new in LabView. Some idea ?
I would like to purchase some good russian valves, but I have seen that all of them (at reasonable prices) are from the outside of the EU. Somebody knows an EU provider ?
Cheers !
Old 28th January 2013, 08:34 PM   #38
mogliaa's Avatar
Hi Anatoliy,
Do you have grid current information from the datasheet to estimate the value of the grid leak resistor?
Ale
Old 28th January 2013, 08:42 PM   #39
Wavebourn's Avatar
No, it is not specified, and varies from tube to tube. They did not need high resistances in grids, for intended application in rockets at UHF.
Low space / Low cost B20 Trooper46 Full Range 5 13th September 2008 05:01 PM
Extremely low power and low loss transformers percy Tubes / Valves 12 23rd February 2005 10:30 AM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
Copyright ©1999-2013 diyAudio
