Old 21st January 2011, 09:58 PM   #21
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
if you wait till tomorrow - I'll post measured data for Priboi OPTs
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 22nd January 2011, 05:27 AM   #22
artosalo's Avatar
I don't know what are they but I found one priboi transformer drawing with Primary (A1) 1200 ( +480V ) 1200 ( A2 ) Sec (GND) 105 ( 4ohm ) 25 ( 8ohm )
By calculating with these the impedance with 8 ohms load will be some 2700 ohms and with 4 ohms load some 2100 ohms.
These values seems too low. I expected some 5 kohms.
This would be great. Thanks.
Old 23rd January 2011, 05:21 PM   #23
tchiwam is offline tchiwam  Finland
Waiting eagerly ! Thank you in advance !
Old 23rd January 2011, 05:38 PM   #24
Zen Mod's Avatar
sorry
xformers are in my workshop , and I had some work elsewhere
tomorrow is work day , again
Old 24th January 2011, 09:32 AM   #25
Zen Mod's Avatar
primary Rdc 87R
pry inductance 9,3H
measured a-a
secondary Rdc
0R8 for 4R winding
1R1 for entire winding (8R)
voltage ratio 18,4:1 ( measured full pry to full sec (8R tap and gnd tap)) , which means that Raa=2K7
Old 24th January 2011, 10:27 AM   #26
artosalo's Avatar
Thank You.
Old 24th January 2011, 06:59 PM   #27
artosalo's Avatar
I have continued the "remote-repair" project of a modified Priboi with 6550 output tubes. This means that an non-experienced newbie makes the measurements I try to explain him and then I try to understand the results.
So far it seems to me that the phase splitter (6N6P) with quite low supply voltage - only some 240 V - can not drive the output tubes "full" before the clipping occurs at the phase splitter itself.
Has anobody noticed this before ?
To improve the phase splitter, I try to take the supply voltage to 6N6P from the high voltage line ( 470 V).
I ended up to the circuit like this.
The potentiometer is here for fine-tuning purpose only and will be replaced with fixed resistor later.
Comments please.
Old 27th January 2011, 11:52 PM   #28
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
By the way, colleagues from Russia who had experience with Priboy said that GU-19 is a beast: it is something between 807 and GU-50, and a pair of them can deliver up to 110W and live long. One gentleman said, they worked 7 years, but started dying all together: some layer from inside of anode started peeling off making spark flashes.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 29th January 2011, 06:01 AM   #29
Interesting, could he expand a bit on the setup ? It is true that the GU-19 are really quality made tubes, ceramic insulators around each leg etc etc and they look good. They work as is in a Priboi at -15VDC but I know I need to adjust more than that. I now have the OPT values...
The GU-29 are on the other hand something out of this world...
Old 29th January 2011, 06:08 AM   #30
Interesting indeed, is this true for the current output tube too ?
How about going to a Shmid or long tail pair type phase spiller while playing with that ? There is already a good gain from the 1st stage... That's where I am heading for the GU-29.
Priboi tweakers ? Zen Mod Tubes / Valves 4 14th May 2007 08:22 PM
Looking for a thread... tubesdude Tubes / Valves 0 5th October 2005 04:25 AM
new thread yariv Forum Problems 1 6th July 2005 10:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
