Yet another Priboi thread...
Old 29th January 2011, 06:39 AM   #31
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by tchiwam View Post
Interesting, could he expand a bit on the setup ? It is true that the GU-19 are really quality made tubes, ceramic insulators around each leg etc etc and they look good. They work as is in a Priboi at -15VDC but I know I need to adjust more than that. I now have the OPT values...
Some people use them as is, some use 4 Ohm tap for 8 Ohm. What is really needed, some heatsinks on anode pins.
Oеhers prefer GU-29.
Also, I know about triode connected GU-50 used there.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 29th January 2011, 08:14 AM   #32
tchiwam is offline tchiwam  Finland
110W in those transformers, lets assume they are the same as in the 75W version, that is still a lot more than designed for. I know Russians didn't have a shortage of copper but I still don't want to grill them.
And yes these are quite low impedence transformers for the output...
Old 29th January 2011, 10:08 AM   #33
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
yes , your fave .....
mind to share your schematic of Priboi with ГУ-50 ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 29th January 2011, 03:26 PM   #34
Wavebourn's Avatar
It was not me; it was Sergey Sergeev, from Irkutsk, Siberia
Sergeev's site about Priboy modifications
Old 29th January 2011, 05:34 PM   #35
Zen Mod's Avatar
tnx W.
Old 29th January 2011, 06:40 PM   #36
Wavebourn's Avatar
tnx W.
You are W., but he got 25W from it only in triode mode!
I would use, of course, in pentode mode with parallel feedbacks around output tubes. Or, stick with GU-19 or GU-29. GI-30 is another option, it is GU-29 with higher cathode emission. The story is, after new equipment was designed for Hall of Congress in USSR, around GU-19 and GU-29 tubes, then Minister got an order to design civil version of the tube. 6R3S-1 was born as the result, birth defected.
Old 30th September 2012, 09:05 PM   #37
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Let's agree to disagree. I can make a nice amp from Priboy using EL34 tubes.
This old discussion has been mostly about replcement tubes in the Priboi amp, like the GU-19.
I have a few questions that is too related to this thread to require a new thread.
Under my bed, I have stored my Priboi (in good company with a Dynaco PAS3 and some hundred tubes - I sleep good at night ). Many years ago I modified it to Likhnitsky's schematic, but as I have ended up with loads of amp projects around or below 10W I started to consider do a new remake, getting som more watts from it.
So, IF I am to switch to other tubes, what tubes can be used? Likhnitsky mentioned that he had tried EL34 with good result before redesigning.
And what's the maximum power that the components (power transformer + OP transformers can provide)?
I have been thinking of EL34 or 6L6, or even parallell 6L6, but I also have a pair of EL156 and KT120 - could these be used? Or is maybe KT88 or KT90/KT100 a better choice?
There was a Priboi-UM75 with 6R3S in parallell, that, according to the name was capable of 75W/channel, but I dunno if there were other and heavier transformers for that model.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 8th January 2016, 01:28 PM   #38
alg0r1tm is offline alg0r1tm  Belarus
Зачем вам ГУ-50? Генераторные лампы сами по себе не предназначены для УНЧ.
Используя генераторные лампы в Прибой УМ, можно легко убить выходные трансформаторы.
Old 8th January 2016, 01:35 PM   #39
Mooly's Avatar
English only please. RULES
Why do you need Gu-50? Generator lamp by themselves are not intended for ULF.
Using the generator lights in MIND, you can easily Surf kill output transformers
Yet another Priboi thread...Hide this!Advertise here!
Priboi tweakers ? Zen Mod Tubes / Valves 4 14th May 2007 08:22 PM
Looking for a thread... tubesdude Tubes / Valves 0 5th October 2005 04:25 AM
new thread yariv Forum Problems 1 6th July 2005 10:11 PM
