Yet another Priboi thread...
Old 15th December 2010, 04:02 AM   #11
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by tchiwam View Post
The GU-19 indeed look like a plug in replacement, anyone here has done the conversion ?
Trouble is I still have a big stock of the 6R3S-1...
So use them while they are alive...
Looks like they took a bulb from Gu-19, and put inside simplified internals from Gu-29.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 15th December 2010, 08:16 AM   #12
tchiwam is offline tchiwam  Finland
I ordered 4 GU-19... Seems that all parameters should at least allow them not to blow when swaped, then again what will be the sound like ???
Old 4th January 2011, 08:05 PM   #13
Found some GU-29 lamps and sockets... I have enough boards to practice with those and the GU-19...
Old 5th January 2011, 12:12 AM   #14
OAA7 is offline OAA7  Ukraine
OAA7's Avatar
be careful with this tube (gu-19), it's UHF tube, if your amp will transform to uhf generator, you may damage your hf-speaker...
Old 5th January 2011, 01:02 PM   #15
Olrum is offline Olrum  Ukraine
Banned
Modernization, "Priboi" long held in Russia.Iz all options no matter how strange the best were on 6R3s and GU29.
GU-19 is not working properly and the sounds of little use for audio.
EL34 absolutely not suitable for use in this amplifier, as suggested some.
Old 6th January 2011, 05:47 AM   #16
Any recommended voltages for the grid ? Or changes to go with the GU-29 ?
I now have both GU-19 and GU-29 on their way home. I know the GU-29 ask for forced air cooling, but I doubt I'll run them to their maximum I don't know what to expect on the power output with the GU-29, these are monsters.
Old 6th January 2011, 06:46 AM   #17
I was thinking to go as such...
Ua = 420V Would like to keep it like that unless the 75W version 480V tap is somewhere in there...
Ug2 =< 225V, now at 240V
This is the max voltage for that grip so a little change on R21 and R24
Bias =~ -20V
Change R14 and R15 to go from -35V to -20V
Old 21st January 2011, 04:02 PM   #18
artosalo is offline artosalo  Finland
artosalo's Avatar
I try to "remotely" locate a problem with one Priboi where the output tubes have been changed to 6550.
The owner has measured only some 20 W output power before clipping occurs.
The screen grid voltage is only 250 V and control grid bias - 24 V. The cathode current is some 65 mA.
Does anybody know what is the nominal impedance or turns ration (to 8 ohms output) of the original output transformer of Priboi ?
Is this conversion (6R3S to 6550) anyhow typical ?
Does it require some modifications to the circuitry ?
Old 21st January 2011, 06:03 PM   #19
Wavebourn's Avatar
Let's agree to disagree. I can make a nice amp from Priboy using EL34 tubes.
Old 21st January 2011, 09:45 PM   #20
I don't know what are they but I found one priboi transformer drawing with
Primary (A1) 1200 ( +480V ) 1200 ( A2 )
Sec (GND) 105 ( 4ohm ) 25 ( 8ohm )
So I guess it is the number of turns, and this would be 130 turns for 8 ohm on the secondary. I am going to pick up my sig generator some of these days and try to calculate the impedence of the input unless someone else can tell me what it is...
I found out that at least on mine the Anode voltage is +480V ! and not +420V like the schematics seem to indicate.
Yet another Priboi thread...Hide this!Advertise here!
Priboi tweakers ? Zen Mod Tubes / Valves 4 14th May 2007 08:22 PM
Looking for a thread... tubesdude Tubes / Valves 0 5th October 2005 04:25 AM
new thread yariv Forum Problems 1 6th July 2005 10:11 PM
