diyAudio Sponsor
Old 11th September 2010, 07:10 AM   #1
ervinl is offline ervinl  Indonesia
Default Help Old Radio Philips
I have old Philips radio with phone/amplifier inputs. The type could be 483X-05 (not sure due to letter is not clear), NR E10999E00.
Anybody has this schema?
I would like to refresh/change the tube. The rect tube pinout is similar to AZ1, but the type is not clear (almost gone). Should have higher rating than AZ1 (but what tube type?).
The power tube is EL3??. I guest EL34, but it is wrong since the pinout (socket) is not octal (although 8 pin), almost like AZ1 (4 pins wide space, 4 pins short space). Seems like EL3, but not sure since there is additional number/letter after that. It is Miniwatt.
And about driver, somethink like EBF??. With a cap.
Thanks,
Ervin L
Old 11th September 2010, 07:33 AM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Ervin, got a picture? I can't find that type.
Old 11th September 2010, 02:39 PM   #3
Hi:
Try contacting the American Radio Museum in Bellingham, Washington. They have at least 10,000 different old tubes and lots and lots of radios, parts, and expertise from a group of volunteers that really know their stuff when it comes to radios.
There website address is: American Museum of Radio & Electricity
Old 11th September 2010, 03:32 PM   #4
See the attachment for picture. Not so clear. May help.
Thx,
Ervin L
Old 11th September 2010, 04:43 PM   #5
davorin is offline davorin  Croatia
EL3N I think.
AZ2(120mA) and AZ4(160mA) are stronger tubes than AZ1(100mA), with same socket connection(pin-compatible).
For 1xEL3N as an output tube, You need AZ1. Your AF-driver is EBF1.
Old 16th December 2010, 07:17 PM   #6
acarp is offline acarp  Bulgaria
EL 3, Tube EL3; Röhre EL 3 (EL3)
EK 3, Tube EK3; Röhre EK 3 (EK3)
http://www.scottbecker.net/tube/sheets/005/a/AZ1.pdf
Old 16th December 2010, 09:30 PM   #7
DF96 is offline DF96  England
As it seems to be a European design you could try asking here, but better pictures might help.
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
Philips CD 721 or Philips CD 710 info5 Digital Source 2 13th January 2010 09:22 PM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Wanted: Vintage radio schematic - Philips B5CA66U (India) Dr. Ram Everything Else 3 23rd June 2008 03:24 AM
Philips Tube radio Grifon Tubes / Valves 5 20th September 2007 03:40 AM
Page generated in 0.09372 seconds (75.45% PHP - 24.55% MySQL) with 11 queries
