diyAudio Sponsor
Old 2nd February 2012, 04:44 AM   #41
Not pretty but should do.
Old 2nd February 2012, 01:23 PM   #42
Early in this thread the question was of how to sample plate current without a differential probe was raised. A differential input amp was shown, but it looked like that had a very limited input voltage range, limiting use the the ground leg of the plate supply or the cathode (which would need the grid currents subtracted to be accurate. One alternate method that would provide isolation is the hall effect sensor. It functons like a (powered) current transformer having DC response. Another is to use a linearized opto-coupler. In a unit with an LED and TWO photodiodes, using the second diode in the feedback loop of an amp driving the LED, the transfer function to the second (isolated output) photodiode becomes linearized. Doing that is described in Vishay Semiconductor app note 50, Designing Linear Amplifiers Using the IL300 Optocoupler. http://instruct1.cit.cornell.edu/cou...pn50vishay.pdf
Old 3rd February 2012, 08:52 PM   #43
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Very interesting way of isolating the measurement of the anode current. With two op amps and the IL300 you can get the job done. Have you tried this?
Cheers, ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 3rd February 2012, 08:53 PM   #44
mogliaa's Avatar
Which frequency are u using on your grid signal?
Are you still driving anode with mains rectified and not filtered?
Cheers
Ale
Old 4th February 2012, 01:51 AM   #45
The steps are at 240hz. The plate signal is rectified with a bridge rectifier giving me humps at 120hz. So with the grid steps at 240 there is a step on the upward going half of the hump and another step on the downward going portion of the hump.
Alfredo
Old 4th February 2012, 10:42 AM   #46
mogliaa's Avatar
Hi Alfredo,
Thanks. So I could simple drop in your 4046/4017 stage before my 4520 counter as I'm using a similar clock circuit (instead of a 555 as ST I'm using a LM311 comparator) and with a mains frequency of 50Hz (UK) I could get a clock frequency of 200Hz. Do you think it will be enough to improve the screen refresh?
Thanks,
Ale
Old 4th February 2012, 02:02 PM   #47
Cheers, ale
No, there are not any feedback enhanced optos in test equipment here yet. To avoid extra floating power supplies and circuitry at high voltage, I'm leaning more towards use of Hall effect current sensing. I was looking at the opto-isolators for a feedback path in another application, but concluded that besides bringing more complexity than I wanted, they were too marginal in terms of bandwidth, linearity, and signal to noise ratio to be part my quest to rid the world of evil screen-induced kinkiness distortions in pentode-connected amps.
Old 4th February 2012, 03:00 PM   #48
Hi Alfredo,
Thanks,
Ale
Yes, right before the 4520. It should improve as the complete step family will take half the time. Also, controlling the number of steps per family helps. I currently do this with a comparator that resets the counter. You need to use a precision pot to have good control (to go one step at a time)
Old 4th February 2012, 06:14 PM   #49
I can see it now, homes of the future with 400 Hz power generated from solar power. "Faster refresh for your curve tracers". Adding a little positive feedback to a comparator turns it into a Schmidt trigger which could prevent erratic behavior if there's some noise on the power line sample used for the frequency reference. Sometimes it is more convenient to use the 40106B, 74C13, or 7413.
Old 4th February 2012, 11:10 PM   #50
jackinnj's Avatar
IL300 is a bit faster than the HCNR200 -- I know as I bought a tube of them from a guy about 6 years ago. I think that there's a SPICE model for the HCNR200 floating around -- used to be on HP's website before they spun off Agilent, which was before they spun off Avago.
DIY Curve Tracer for PC locky_z Solid State 179 25th May 2012 02:12 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer barclaycon Equipment & Tools 6 11th February 2010 08:10 PM
Wanted Diy curve tracer! amc32 Car Audio 1 19th October 2009 05:52 AM
DIY tube testing Curve Tracer whitelabrat Tubes / Valves 5 24th October 2007 09:11 PM
Page generated in 0.16141 seconds (61.09% PHP - 38.91% MySQL) with 11 queries
