DIY Curve Tracer
DIY Curve Tracer
Old 24th November 2012, 10:14 PM   #341
jazbo8 is offline jazbo8
jazbo8's Avatar
DIY Curve Tracer
Gents,
Thanks, I could not have done it without your help. As for the arcing, I think it was a separate issue, since the problem did not show up until recently... It was the sloppy construction and the poor choice of the mini-banana jacks that caused the arcing, but I think it had nothing to do with the interference problem I had/have. Even now, in order to get really clean traces, I still have to run the tests during non-business hours.
Jaz
Old 25th November 2012, 08:59 AM   #342
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
DIY Curve Tracer
Have you tried a mains filter yet?
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 26th November 2012, 06:22 AM   #343
jazbo8's Avatar
DIY Curve Tracer
Yes, I did, it did not help... I think I should put the whole thing inside a well shielded chassis - it would be an improvement for sure... Also I am still having some issues with the grid drive, it seems that at the low grid stopper settings (<10k), there's still some parasitic oscillation, it just bugs me that a simple circuit is giving me so much grief I did a lot of things trying to remedy the problem - short, thick signal path, ferrite beads on the leads, regulated supplies... but still not quite there...
Jaz
Old 26th November 2012, 08:57 PM   #344
mogliaa's Avatar
DIY Curve Tracer
Do you get same interference when using the scope measuring low level signals? Try a simple oscillator from a 9V battery and see if it is the noise also coming on your scope. Just a thought to try isolating the root cause...
Ale
Old 27th November 2012, 01:05 AM   #345
jazbo8's Avatar
DIY Curve Tracer
Ale,
Yes, I have tried to isolate the problem using other circuits (both battery and bench supply powered), so far, I am pretty sure the issue is limited to the adapter itself - a combination of the circuit topology, wiring, construction & layout. I have other circuits running without problem, since I have used such point to point wiring in the past many times successfully and followed the standard practice for grounding and routing... but I am sure I missed something along the way, just need to track it down and fix it...
Jaz
Old 27th December 2012, 06:28 AM   #346
jazbo8's Avatar
DIY Curve Tracer
Anyone has experience with the 6P15P (or 6n15n)? The only way I could make the pentode curves match those in the datasheet was to connect the suppressor grid (g3) to the control grid, when I connect the g3 to the cathode (as it would be in most circuits), I get strange looking curves.
G3-G1 on the left, G3-Cathode on the right:
TIA,
Jaz
Old 27th December 2012, 11:33 AM   #347
v4lve lover is offline v4lve lover  Netherlands
DIY Curve Tracer
the datasheet specifies 150v on G2 for these.
what g2 voltage are you testing at ?
Old 27th December 2012, 12:01 PM   #348
jazbo8's Avatar
DIY Curve Tracer
Tested with 150V on g2, did I overlook something? Why can't g3 be grounded on this tube?
Old 27th December 2012, 01:22 PM   #349
Yvesm is offline Yvesm  France
Yvesm's Avatar
G3 MUST be grounded indeed.
It looks like if you measured the cathode current (i.e. anode + G2 + G3) rather that anode current alone ? ? ?
Yves.
Old 27th December 2012, 02:37 PM   #350
mogliaa's Avatar
DIY Curve Tracer
If you're sensing current on the cathode return then g2 supply has to be floating with return on the cathode, otherwise you will sense anode and screen current
Ale
DIY Curve TracerHide this!Advertise here!
curve tracer barclaycon Equipment & Tools 7 6th March 2017 01:18 PM
DIY Curve Tracer for PC locky_z Solid State 470 22nd May 2015 05:13 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
Wanted Diy curve tracer! amc32 Car Audio 1 19th October 2009 05:52 AM
DIY tube testing Curve Tracer whitelabrat Tubes / Valves 5 24th October 2007 09:11 PM
