DIY Curve Tracer - Page 34 - diyAudio
Old 15th November 2012, 02:26 AM   #331
jazbo8's Avatar
Gents,
I am in the process of making v.2 of my tracer - need to improve the layout and the chassis. But I was thinking about another way to go about it and want to run it by you guys to see if it is feasible...
Here is the basic idea - use PC based scope and generator (which would eliminate many knobs and some real estate on the front/panel and controller board) and an external power amp to drive the grid. Like this:
Not very sophisticated, I know... but what do you think?
TIA,
Jaz
Old 15th November 2012, 05:10 PM   #332
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
Send a message via Skype™ to v4lve lover
why don't you guys just use a XY plotter instead ?
Hp made some 0-300v 100ma power supplies, use another 0-60v for bias purposes. add a heater supply and your all set
Heck, be course a Xy writer is tracking you could even use a unregulated supply for example just a mosfet source follower.
cheers, V4lve
Old 16th November 2012, 12:35 AM   #333
jazbo8's Avatar
cheers, V4lve
Have not seen a XY plotter for sale in ages... And the data is still on paper not in the PC (for creating Spice modesl and whatnot)...
Jaz
Old 16th November 2012, 08:20 AM   #334
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Jaz,
A different route that will bring its own challenges. Have a look at Yves design. He posted the link to his website earlier in this thread. His tracer is based on a PC. Also Michael Koster was working on a digital tracer as well. Not necessarily a simpler project.
When I first built it as a breadboard, there was no shielding, minimum ferrite beads and long cables. Despite this mess, it worked fine. My only challenge has always been keeping the sync due to the PLL stability. That is something it can be improved.
I will encourage you to continue looking at what may be not working for you as you are very close to the end goal now!
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 16th November 2012, 01:05 PM   #335
jazbo8's Avatar
Originally Posted by mogliaa View Post
Jaz,
Ale
Ale,
I am still planning to complete v.2 of my manual curve tracer for sure. I tried Yves' program but could not make it run properly on my PC, but it looks very good from the pictures on his site...
Jaz
Old 16th November 2012, 01:44 PM   #336
jackinnj's Avatar
Jaz
I have an HP7470 Plotter which is very easy to use -- if you know how to configure the serial port (a legacy art which is lost to the foggy mist of the ages for all I-Pad users.)
You can always take the data from paper and convert it to a table with a "grabber" program. I've done this for some ham radio tubes for which SPICE is non-existent, and you might have seen the equations i worked up for LDR's using this method.
Best of all, just get a little data-logger, they're less than $50.
Old 16th November 2012, 02:08 PM   #337
jazbo8's Avatar
No doubt the X-Y plotter and the data-logger would work fine, but I like to avoid the in-between steps as much as possible - so using PC based test software such as TureRTA, Visual Analyser, Daqarta, etc. might be a way to go. I am sure there are some issues to be sorted out, such as soundcard interface/buffer, line sync, etc. More things to try/play with...
Jaz
Old 24th November 2012, 07:31 AM   #338
jazbo8's Avatar
I finally completed the adapter... Thanks to Alfredo and Ale for the inspiration and assistance during the troubleshooting phase. I also made a new front panel to replace the beat-up one used in the previous version. I posted the results at DIY Valve Curve Tracer Adapter v.2 jazzbo8's adventure
Jaz
Old 24th November 2012, 04:01 PM   #339
Jaz, it looks great! Congratulations. So the problem was the arching?
Old 24th November 2012, 09:02 PM   #340
mogliaa's Avatar
Jaz,
Great, well done! What wasn't working For you before? What did you fix?
Cheers
Ale
DIY Curve Tracer for PC locky_z Solid State 470 22nd May 2015 06:13 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 09:22 PM
curve tracer barclaycon Equipment & Tools 6 11th February 2010 09:10 PM
Wanted Diy curve tracer! amc32 Car Audio 1 19th October 2009 06:52 AM
DIY tube testing Curve Tracer whitelabrat Tubes / Valves 5 24th October 2007 10:11 PM
Copyright 1999-2017 diyAudio
