Old 2nd October 2012, 12:11 PM   #271
jackinnj's Avatar
Ale: You've done such nice work on the instrument, why not get a silk-screen kit for the lettering.
Old 4th October 2012, 02:06 PM   #272
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Originally Posted by jazbo8 View Post
Ale,
Sorry to bother you again... What are the front panel controls highlighted in the attached picture? I can't see them on your schematic.
Thanks,
Jaz
Hey Jazz,
I'm on the road with no laptop.
Ia: is the pot for the dn2540 cascoded CCS I use for measuring transconductance and THD
G: grid output to calibrate steps using the scope
Grid zero: bias pot to set Grid starting point of Vgk curves
Switch on the bottom is power switch
Ia switch disconnects HT from CCS
All that part of the circuitry blew up with my last 600V test. Hopefully I will sit down to repair it when back
Cheers
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 4th October 2012, 02:08 PM   #273
mogliaa's Avatar
You may be right, but haven't done that before, any idea what/where to get it from?
Thanks!
Old 5th October 2012, 12:21 AM   #274
jazbo8's Avatar
Cheers
Ale
Thanks for the clarification.
Too bad about your gm/THD test rig, I read about it on your blog, something to do with Millet's soundcard input, was it? I am still gathering parts for the build and going over the Tek 570 schematic, I'd love to incorporate the Plate-Screen-Grid switch for the vertical amp, but the switching and the extra power supplies are not "DIY friendly"... Those Tek engineers sure knew what they were doing!
Thanks,
Jaz
Old 7th October 2012, 01:12 PM   #275
mogliaa's Avatar
Default Leakage testing circuit
Thought about the addition of a simple short/leakage testing to my tester. Now that will have to open and do some repairs, I can easily drill a couple of testing connectors and use existing +/- 80V supply available.
I thought about the proposed leakage circuit in the Sussex tester, so came up with the simple modification in the attached.
With a couple of probes can use this to test anode/grid leakage, filament continuity and cathode leakage as well.
Only concern is whether gain is too much. MPSA42 has an hFE=90@Ic=1mA. So input sensitivity is about 5uA to light the russian neon bulb.
Looked around for grid current values thresholds used in testers but couldn't find any. Old testers use a simple neon bulb to identify leakage so I guess they are measuring 100uA or above in order to get a dim light on the neon bulb?
Suggestions?
Ale
Old 7th October 2012, 04:40 PM   #276
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
Send a message via Skype™ to v4lve lover
see the Neuberger tube manual . http://www.jogis-roehrenbude.de/Roeh...400/RMP400.pdf
There is a part about grid current See Page 18b
"the value of the measured grid current can be used as a criteria, as a rule of thumb
Tubes whit a Bad vacuum (tested bad on the procedure in 18A)
preamp tubes whit less than 4 uA are usable
output tubes whit less than 10 uA are usable
tubes that are good and show little Gas on the gas test.
should have less than 0,6-1uA for preamp tubes and less than 1.5-2 for output tubes.
lot of useful data in that manual.
v4lve
Old 7th October 2012, 04:49 PM   #277
mogliaa's Avatar
Thanks v4lve!
So in principle 5uA is not bad at all for this purpose. This circuit should work fine. Can build it very quickly and report results.
Only point is that output valves with 5-10uA will turn on the lamp
I'm trying to avoid the addition of a grid sensing resistor and an op amp and the output to measure the grid current externally, no additional space inside the tracer am afraid.
Ale
Old 7th October 2012, 04:50 PM   #278
mogliaa's Avatar
v4lve
Wish I could translate this, but unfortunately don't speak German!
Old 7th October 2012, 09:27 PM   #279
jazbo8's Avatar
I'm also thinking about incorporating a shorts test into the tracer, I like the B&K version, the detailed schematic is in the B&K 747 tester if you want to take a closer look, the basic setup is as follow:
Jaz
Old 19th October 2012, 01:09 AM   #280
jazbo8's Avatar
Default How to get rid of re-trace?
I ran a quick test on my adapter this morning, it worked BUT how do I get rid of the re-traces from the display? I played with the Phase and Sweep adjustments (per Ale's schematic), but they did not seem to have an effect... I also tried blanking the Z-axis by connecting the Y-sweep to it, which helped may be a little, but most of the re-traces remained... Did I overlook something obvious?
Jumbled curves:
TIA,
Jaz
DIY Curve Tracer for PC locky_z Solid State 414 Yesterday 07:31 PM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer barclaycon Equipment & Tools 6 11th February 2010 08:10 PM
Wanted Diy curve tracer! amc32 Car Audio 1 19th October 2009 05:52 AM
DIY tube testing Curve Tracer whitelabrat Tubes / Valves 5 24th October 2007 09:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
