DIY Curve Tracer - Page 27 - diyAudio
Old 21st September 2012, 11:13 PM   #261
jazbo8's Avatar
Originally Posted by jackinnj View Post
Tube tester has a "short" test which is the first test you should (always) perform!
I just got an Arduino Leonardo which is going to form the basis of a new, open source, tube and transistor tester.
Please tell us more, is it similar to Michael Koster's concept?
Jaz
Old 22nd September 2012, 08:38 AM   #262
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Originally Posted by mogliaa View Post
Thanks Alfredo, will look at this!
A quick example for 4P1L curves. Quite interesting tool indeed
http://www.bartola.co.uk/valves/wp-c...P1L-curves.png
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
Old 22nd September 2012, 03:42 PM   #263
jackinnj's Avatar
Jaz
No, not really. I have no issues with transformers.
The Leonardo behaves as if it were a USB device, i.e. no FTDI chip.
I published a tracer article about 10 years ago using the Basic Stamp -- it worked but was slow due to communication speeds. I've gotten a lot better at current sensing, stabilising power supplies etc.
The important thing for me is to be able to dump the data into Eurequa to come up with equations.
Old 22nd September 2012, 03:57 PM   #264
mogliaa's Avatar
How difficult is to work with Eureqa to produce the triode model?
I've been using Dmitry's paint tools with good results except for power transmitting DHTs..
Old 23rd September 2012, 12:48 AM   #265
jazbo8's Avatar
It's pretty straight forward with Eureqa, it take about 10-20 minutes to generate an usable solution. I never got the hang of using Model Curve Painter, the curves never lined up for me... So for triodes, my favorite is still Curve Captor - it's quick, accurate and does loadlines, Pd and THD calculations on-the-fly.
Jaz
Old 24th September 2012, 01:44 AM   #266
jazbo8's Avatar
That's a good point... Besides having all the tube sockets pre-wired (a real time-saver), the tube tester also have select-able voltages for the plate and screen (although only up to 300V). Here is the tester I plan on using, if anyone has other suggestions, please let me know.
which is a copy of this Russian unit.
Thanks,
Jaz
Old 26th September 2012, 10:05 PM   #267
Default Curve Tracer as-built Schematics
Some people have been PM'ing asking for the circuit schematics. I finally got around to do it.
Old 1st October 2012, 12:31 AM   #268
jazbo8's Avatar
Originally Posted by avincenty View Post
Ale, great job! See you have been busy tracing.
I built a camera hood that works great for me. It is made of 1/4 inch hard foam that is used for posters. The hood is light and strong and snaps tightly against the oscilloscope screen frame.
What settings are you using on the camera? I think you mentioned that you have a storage scope as well, right? BTW, thanks for posting the as-built schematic.
Jaz
Old 1st October 2012, 01:05 AM   #269
I don't recall the camera settings, since I am using the storage scope as well it is very easy, I only adjust the intensity on the scope until it takes a good picture. (usually very low intensity)
Alfredo
Old 2nd October 2012, 03:47 AM   #270
jazbo8's Avatar
After a lot of work (more than I thought it was going to take), managed to bring the valve curve tracer to life.
Ale
Ale,
Sorry to bother you again... What are the front panel controls highlighted in the attached picture? I can't see them on your schematic.
Thanks,
Jaz
curve tracer barclaycon Equipment & Tools 7 6th March 2017 01:18 PM
DIY Curve Tracer for PC locky_z Solid State 470 22nd May 2015 05:13 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
Wanted Diy curve tracer! amc32 Car Audio 1 19th October 2009 05:52 AM
DIY tube testing Curve Tracer whitelabrat Tubes / Valves 5 24th October 2007 09:11 PM
Copyright 1999-2017 diyAudio
