Old 5th June 2012, 06:16 PM   #231
euro21 is offline euro21  Hungary
C3g (triode strapped): 11mA CCS, 230R+100uF in cathode.
About four dozen used tubes.
5.9-7.4V RMS out, 0.031-0.068% THD
52-66V RMS out, 0.14-0.55% THD.
Old 5th June 2012, 06:37 PM   #232
C3m (triode strapped): 160V, -6V, 100R in cathode, 16mA anode current.
Two dozen used tubes.
70Vpp out, 0.11-0.61% THD
160Vpp out, 0.28-0.99% THD.
240Vpp out, 0.50-0.96% THD (six tubes already clipping).
Excellent driver tubes, but requires selection.
Old 5th June 2012, 06:38 PM   #233
7N7 is offline 7N7  United Kingdom
7N7's Avatar
Excellent numbers; the C3's reputation is obviously well deserved.
Plug them in and light them up
Old 5th June 2012, 08:23 PM   #234
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
had to bring my ferrograph RTS2 test set back to life to test THD somehow. And indeeed I screwed up Pete Millett's interface. Measured THD on 26 at Ia=6mA, Va=160V and Vg=-10V on a RCA ST valve and THD was 0.05% @ 10Vrms
Now, need to repair Pete Millett's interface!
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 5th June 2012, 09:54 PM   #235
7N7's Avatar
Yes a good figure 0.05% - about -65dB I think. Trouble is that at these levels one really has to trust one's test gear
P.
Old 6th June 2012, 01:26 PM   #236
Trust in God, and keep your powder dry! :-)))
My basic test equipment:
Heathkit IG-18 (strongly modified, only sine wave) 0.001-0.002 % THD;
Leader LFG 1300S 0.1-0.15% THD sine/square;
Kenwood VT-176 dual channel AC voltmeter (300uV-100V), dual output to sound card (max. 1V);
1:10 scope probes;
2 ch passive preamp (for low value THD measuring) -protecting sound card input-;
M-Audio Transit USB sound card;
Visual Analyzer program (running on laptop).
Old 6th June 2012, 03:17 PM   #237
They say "You can't beat Wales at Rugby - you can only score more points than them"
I say "You can't beat the 26 as an input tube - you can only get better figures".
andy
Old 6th June 2012, 03:22 PM   #238
mogliaa's Avatar
andy
Andy,
The analysis was only around THD and specially the tube's linearity at large voltage swings. I do like 26 and 01a a lot, no doubt about that.
Both tubes have THD around 0.02%-0.06% at low signal levels...
Trouble is here that I screwed up my Pete Millett's audio interface whilst playing with these valves!
cheers,
Ale
Old 6th June 2012, 03:22 PM   #239
7N7's Avatar
Yes. When I was doing this, the equipment I used was a BBC EP14 distortion test set, Marconi wave analyser, Marconi HF voltmeter, Tek 60MHz 'scope.
I also had a signal generator and a function generator, but the distortion from these was risible.
The BBC set's THD was around -65dB anyway, so it was better that I tested at higher levels. Even though I no longer have the equipment I do still have the data in my book.
As a matter of interest I did a lot of testing on type 955 "acorn" triodes, because I built a line stage with them. As single valves with 50k resistive anode load, about 140V on the anode, driving my usual 30k pad, THD at +28dB (19v rms) was consistently about -37dB (about 1.5%) with 3rd harmonic about 25dB below that. At +20dB (7.75v rms) the figure was -45dB. However, configured as differential pairs which I have used in the line stage, still with resistive loads, at +28dB, THD was -63dB (0.07%) with 3rd at -70dB (0.03%), which is perfectly acceptable to me!
Paul
Old 6th June 2012, 06:04 PM   #240
mogliaa's Avatar
Ale, I think you have a little weak bunch of #26s. :-)
Each of all -in my collection four ST type Silvertone, and a pair Cunningham CX326- distortion spectrum below -60dB (2nd), and the best pair THD only 0.0526% (7V RMS out).
B+ 220V (Salas SSHV2), heater bias (10R/50W, Coleman regulator), 6mA (DN2540) cascode CCS anode load, 220nF FT3 teflon coupler, 100K Shinkoh resistor as load.
Sylvania 26 ST - randomly picked from the good batch of ST 26 I have:
THD=0.03% @ Vo=7Vrms - to compare against your measure above
THD=0.052% @ Vo=10Vrms - to compare against my damaged audio interface!
Both were tested at Ia=6mA, Va=158V, Vg=-10V using my curve tracer circuit in transconductance mode. Anode load is DN2540 cascoded CCS. Fixed bias. Input and output caps are russian PIO....
Good thing is that my tester is working, bad thing is not only that I damaged my audio interface but that I need to retake all THD measured I did yesterday
DIY Curve Tracer for PC locky_z Solid State 378 4th May 2013 12:26 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer barclaycon Equipment & Tools 6 11th February 2010 08:10 PM
Wanted Diy curve tracer! amc32 Car Audio 1 19th October 2009 05:52 AM
DIY tube testing Curve Tracer whitelabrat Tubes / Valves 5 24th October 2007 09:11 PM
Copyright ©1999-2013 diyAudio
