DIY Curve Tracer
DIY Curve Tracer
Old 4th April 2012, 07:49 PM   #151
jackinnj is offline jackinnj  United States
jackinnj's Avatar
DIY Curve Tracer
The patch cords are dangerous anyway. The hot end should be a protected female.
You may be getting some hash from the diode switching, you may get it from some oscillation as the voltage on the MOSFET is pulled down.
Old 4th April 2012, 09:07 PM   #152
avincenty is offline avincenty  United States
The only exposed points are the test points and my plan is to put some type of hood over the pins. What is a protected female jack? I can't find anyting that mount under the chassis with some type of hook to attache to probes to.
My Plate drive is very simple, same as the Tek 570.
Variac>Transformer>Full Wave Rectifier>Series Resistor>Plate. I can try with some caps accross the diodes.
Alfredo
Old 4th April 2012, 10:28 PM   #153
jackinnj's Avatar
DIY Curve Tracer
I rigged the connection from the tube sockets with mini-banana plugs -- these plug into the anode/grid female jacks. It's just something I've been doing since my ham radio days.
Here's the Pomona "sheathed" female: http://www.pomonaelectronics.com/pdf...2_01_24_06.pdf
Old 4th April 2012, 11:38 PM   #154
Not sure I follow, these are very similar to the ones I am using.
The patch cord is made from cut up voltmeter leads. Male Plug and female Jack mate very solidly. I thought you were talking about the X and Y test pins.
Alfredo
Old 5th April 2012, 02:16 AM   #155
jazbo8 is offline jazbo8
jazbo8's Avatar
DIY Curve Tracer
Not quite the same, the protected plug and jack look like these:
Jaz
Old 5th April 2012, 04:24 AM   #156
Ahh!, yes. Makes sense. However, I still have the exposed pins where I connect the probes to. These have to be taken care of first. I will do a search to see if I find something I can purchase.
I put some .01 1KV caps across the 1n4007's but they where clicking. Once I removed the caps the weirdest thing happened, the hash went away. Wonder if it was just a cold solder.
I mentioned that I was using an analog storage scope to capture he curves. It is a HP 1223a in pretty good shape. Paid 40 dollars, I thing it was worth it as it is very easy to take pictures of the curves without having any refresh issues.
Now I need to put in the finishing touches. Need to install the voltmeters, one for the heater voltage and another for the external screen voltage. I have some but they are meant for a smaller square opening. I would need to fabricate an adapter plate or purchase some new ones.
For the lettering I will give inkjet decals a shot, my handwriting wont cut it. Also need to fabricate new sides. I had to add some spacers between the top and the bottom to make everything fit. The original sides are too short now. I will fabricate new sides and front from MDF and paint the same hammer green as the socket adapters.
Cant wait to finish to do something else.... Next is a 6528 PP amp
Alfredo
Old 5th April 2012, 04:35 AM   #157
jazbo8's Avatar
DIY Curve Tracer
"It is a HP 1223a in pretty good shape. Paid 40 dollars..."
Now you are just trying to make me jealous.
Jaz
Old 5th April 2012, 11:06 PM   #158
With the hp 1223a i can cheat a little. Grid to ground. One screen voltage at the time, saved into the storage memory.
Old 8th April 2012, 08:51 PM   #159
Default 6080 dual power triode
More testing today....
Video showing the matching feature of the curve tracer on the RCA 6080. The 6080 was the first one that I pulled from my batch of NOS tubes, all are RCA. I was very surprised that both sections are spot on.
I checked this feature with a bunch of used 12AT7 and only two out of 7 were close enough, most were way off.
Old 8th April 2012, 10:51 PM   #160
one more...
A trioded PL-36. On this one I tried 2 captures on the storage oscilloscope to extend the grid steps past -60. BTW, the plate voltage is way past what the datasheet specifies. Datasheet specifies 250V max.
DIY Curve TracerHide this!Advertise here!
curve tracer barclaycon Equipment & Tools 7 6th March 2017 02:18 PM
DIY Curve Tracer for PC locky_z Solid State 470 22nd May 2015 06:13 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 09:22 PM
Wanted Diy curve tracer! amc32 Car Audio 1 19th October 2009 06:52 AM
DIY tube testing Curve Tracer whitelabrat Tubes / Valves 5 24th October 2007 10:11 PM
Copyright ©1999-2017 diyAudio
