#121 |
Thanks Ale.
None of my transformers are back to back. They do share the bias voltage that i am injecting via the center taps. I want to draw the schematic and post it. What software do you use? Now that you are running at 200hz you could use the 4th bit on the clock and get 16 steps. Been reading lots of posts on the 4p1l. May need to get some of those. I have been testing cheap tv tubes i got for $1 and dont mind ruining a few. A while back I did build a trioded pp amp for my dad using the 6eb8 and cheap speco 7010 transformers and it sounded fantastic. Photo Gallery I took everything apart yesterday and I am trying to figure out how to stuff it all into a case i found. My original thought was to use an old tube tester as platform but i am changing my mind. I may go with adaptor modules that i plug into the chassis. I need to go to my surplus store to see if i find a generic male/ female plug/sockets with at least 12 connectors (to support compactrons, have a bunch). Will take pictures of the build. Alfredo |
#122 |
Finally sorted the issue with the PLL locking. Tried all suggestions and still got the issue until I realised that the issue was impacted by the type DUT and current dragged by it. So found out that the back to back voltage sagging was impacting the clock and it seemed so obvious that why I didn't look to that before!
Anyway, added a simple 6V transformer to feed the PLL clock signal and now works like a charm. What I found with tubes such as 6N7 and other ones that needed to remove the grid resistor (10-200K) to avoid double tracing and some oscillation. Tried all sorts of tubes with different GMs, power tubes, triode strapped, etc. and it seems like it works better for me without the grid resistor. Weird, but it does... Regarding cad software i'm using an old coreldraw which is a pain in the back although the diagrams look neat. You may want to look for much better options out there... Just ordered a couple of 230/230V toroid trafos to use as the main supply for the anode circuit and that should work fine... Started thinking about the chassis and want to use the similar concept as my breadboard box with all the plugs as in the attached
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp) http://www.bartola.co.uk/valves/ |
#123 |
Glad to hear that your clock issues got resolved. I want to do something similar to what you have done with your breadboard. If I find some good 12 pin male/female plug and connector then I would build different adapters for the various socket types. I am also planning to buy some ferrite beads to put on the wires connecting the the adapters.
I found this case at my local surplus store. I am planning to put one digital panel meter for the filament voltage and one for the screen supply fed from an external regulated supply. Over the weekend I assembled the Variable HV supply. It is a variac connected to a 1050V CT transformer (rated at 250ma) Voltages show are RMS. This will be the heater supply. Internally it has three 6.3V 4 amp series connected filament transformers. |
#124 |
Alfredo,
It's looking terrific, well done. I wish mine ends up looking like that. I want to add a couple of more functionalities to my curve tracer as I'm going to drill so many holes for multiple sockets, so probably will add the capability to measure gm with an active load (e.g. gyrator/CCS) and simple leverage the existing power supplies with a simple addition of a couple of LCD meters. Have been tracing many valves over the last weekend and found interestingly that not always the grid stopper (usually 10K) was effective. In some cases had to remove it, so probably may add a switch to bypass the grid stopper resistor, what do you think? In the cases that the grid stopper didn't work, I got a slight double trace and it was gone once the grid stopper was removed. I have also traced the famous GU-50 in triode strapped. Just used for the first time an 230/230V 80VA toroid I purchased early this week: My Photos Cheers, Ale
#125 |
Hi Ale,
Thanks. Your curves look great, very clean. I guess you never needed the phase adjustment. On mine i do need it to clean the curves up. On my curves, if the phase is not adjusted I don't get a straight "series resistance" load line on the tips of the curves. As far as the grid stopper go, i have been debating the same thing myself. The largest I have used is 1K. I was thinking of using a switch to select short,100,1000 and binding post so I can have flexibility. As mentioned, I want to try some ferrite beads. I never used them before so I don't know if it will make a big difference. I have not been able to find a good solution for multi pin male/female connectors so I might end up putting one of each socket. I hope I can have some progress this weekend. Alfredo |
#126 |
I cant sync better the curves as shown. Specially at the end of the curve I cant get rid of the retrace. But overall is ok and I'm a happy man.
Ferrite beads are good, I have a bunch of them but your idea is probably the best. I will add a selector switch with a set of none, 10, 100, 1k and 10k grid stoppers. Sounds like a plan. I will try to post updated diagrams over the weekend. Challenging tubes are high gm ones. Those are the ones to play with and see the results :-) Cheers, Ale
#127 |
ALfredo,
Do you want a challenge? Try tracing a 6e5P in triode mode! That's a pain in the back. Had to ground a filament end to stop oscilation as there was no grid stopper capable of doing the job! I know that my breadboard setup is not ideal (long cables, etc.) but haven't had a similar challenge with other pentode triode strapped or a high mu triode such as 6s45p. Some latest traces here: My Photos cheers, Ale
#128 |
As haven't started with the curve tracer chassis yet, I've been thinking in a small addition to the whole tester/tracer. It seems to me a waste of valve connectors not adding a simple test gig in addition to the curve tracer.
I usually measure valves distortion with a breadboarded jig and Pete Millet's audio interface to the PC. It works very nice, so I thought about the circuit drawn in the attached. A simple jig with a grid voltage pot, a gyrator load, an anode current meter and a transconductance meter. The jig uses the PC sound card to feed test signal and to measure (THD and THD/frequency). Transconductance is measured through a 200mV AC RMS meter as in the Sussex Valve Tester with the difference that the source test signal is provided by the PC: a 1kHz 100mV rms sine. I think this could be a good addition to the tracer to measure: 1) valve operating points 2) Transconductance at operating point 3) THD 4) THD Frequency response 5) Mu Thoughts? Any improvement suggestions? Thanks Ale
#129 |
Hi Ale,
You are building a super tester! How do you measure the DUT with PMillett's inteface? Is it a simple SE setup with a transformer? Those russian tubes in your pictures look really good. Wish i had some. Yesterday a bought 11 6080 for $6 each. Have OTL in mind. I have been thinking about the final chassis layout and i think i will include additional posts so I can also trace different feedback topologies, Schade, cathode, etc.. I am planning to do some work today...... |
#130 |
Valve is loaded with a gyrator at the operating point you want. You can feed a sine wave with Audiotester (or any other software of choice) and then measure gm from the meter and THD using Audiotester,etc.
Simple and very useful. I can sen you some Russian valves if you need. Let me know I'm thinking of a set of 8 valve sockets for my tester ranging from 4pin to 12 pin compactron... Cheers Ale
| DIY Curve Tracer for PC | locky_z | Solid State | 414 | Yesterday 07:31 PM |
| B-H Curve Tracer | gpapag | Equipment & Tools | 9 | 16th January 2011 08:22 PM |
| curve tracer | barclaycon | Equipment & Tools | 6 | 11th February 2010 08:10 PM |
| Wanted Diy curve tracer! | amc32 | Car Audio | 1 | 19th October 2009 05:52 AM |
| DIY tube testing Curve Tracer | whitelabrat | Tubes / Valves | 5 | 24th October 2007 09:11 PM |
