To Schade it , or not..
Old 4th September 2010, 08:32 PM   #1
Mosquito is offline Mosquito  Argentina
Mosquito's Avatar
Default To Schade it , or not..
After drinking half a Ballantines bottle, I come out with this thing. Now, ten "ristretto" coffees after that, I start to suspect that there is something wrong about this plate to plate connection. Schade can wait?
"It is less serious than if worst"
Old 4th September 2010, 11:03 PM   #2
kenpeter is offline kenpeter  United States
As long both AU6 stay in Class A, should be able to tolerate 6V6 in AB...
You got autotransformer coupling of NFB from plate of downside 6V6.
Even when topside 6v6 is temporarily class B'd out the picture.
I don't know this is Schade anymore, but still plate to plate feedback.
I'm a little more worried you got c1, c2, and maybe c5 together with
autotransformer in a feedback loop to control the downsize 6v6. One
corner has to be sufficiently lower than the rest to assure that loop
gain is down below unity before the next pole adds any more pshift.
Would R10 operate better bypassed? We want voltage linearity for
this triode strapped AU6 phase inverter, don't care current linearity.
Old 4th September 2010, 11:12 PM   #3
Mosquito's Avatar
Mmm... I wanted to have some O/P impedance reduction, but maybe is better this one. Of course, being a pure pentode output stage GNF is a must to do
Old 4th September 2010, 11:27 PM   #4
Mosquito's Avatar
The plan was to keep R5 bigger than R7, and C1 smaller than C2
C5 instead, some 30 to 40uF lytic...
Old 5th September 2010, 05:16 AM   #5
Gnd 4 ohm tap and stand output cathodes on 0 and 16...
Though would then need fixed (negative) bias for grids.
See ARC ST-70-C3 for classic example.
Does top AU6 in unbypassed pentode mode make sense
without plate to plate NFB?
Old 5th September 2010, 08:28 AM   #6
Mosquito's Avatar
Yes probably in a nornal GNF scheme it is better to keep R9 bypassed, for a plenty of gain. (It is not pictured, but I want the amp to be an integrated, drived directly by the CDP out, if possible)
R10 unbypassed is part of the measures to have unity gain on the second AU6, a much lower voltage gain, G1 feeded trough a voltage divider, and a lower following grid resistor (R7)
Found the schematic You suggested (ARC ST-70-C3) I'll take a look on it.
Old 5th September 2010, 09:23 AM   #7
Mosquito's Avatar
Maybe for a correct use of Schade local FB it is necessary to build some kind of LTP or differential input stage keeping both AU6's in pentode mode?
To Schade it , or not..Hide this!Advertise here!
O.H. Schade(1938) meets MOSFET revintage Pass Labs 43 11th November 2012 06:56 PM
DC7 MkII :New Schade 6080 amp. Shoog Tubes / Valves 31 23rd April 2011 06:28 PM
What if O.H. Schade had MOSFETs? Michael Koster Tubes / Valves 30 18th January 2011 02:53 PM
DC hybrid folded-cascode for Schade revintage Tubes / Valves 18 13th February 2010 08:09 AM
Iron LTP Schade-PP revintage Tubes / Valves 3 4th October 2009 07:53 PM
Copyright ©1999-2017 diyAudio
